Replace that driveshaft bearing!!!
#121
#122
Thank you for the pictures revshift. Let me restate my post. IF you have an insert and are going to use our poly carrier... Make sure it measures according to the pictures.. Some people have had issues with their insert being too tall for whatever reason.
#123
Now remember the "scientific data".... looks good on paper.
But when the car is noisy and parts are out of alignment going down the road... your data is worthless.
Did you take that picture right after installing that new OEM mount ?
#124
Wonder what the factory mount looks like after 100 miles, a 1000 miles, 5000 miles etc. and I wonder if GM made allowances for it sagging out when they made the mount originally because it looks like it was intended to settle. Is their a service limit speced in the service manual?
#126
I can confirm my revshift trans mount insert is as pictured above after 5k~ hard miles. I have a slight sag, but it definitely doesn't raise the trans up 3/8" higher. Rocking the revshift motor mounts, trans insert, and front CS differential bushing.
I want that driveshaft bearing. Im a DIY'er, anyway you can send a writeup with a ds bearing purchase? I don't have time to send/receive my driveshaft to get serviced.. or buy a whole new DS..
#129
core program is in the works as of yet. We dont really want to offer core exchange services with the OEM style unit when our goal is to produce a more effective poly unit. The write up isnt really an option as of yet either because we haven't developed a process that a DIY'er can do in the garage without having problems.
#131
#134
https://creative-steel.com/store/ind...ct_detail&p=32
Set it and forget it. No additional noise and holds things right where they should be.
