Best Headers for the price/$ install prices in Michigan
What's up fellas, i was reading some past posts about what it costs to install headers and the numbers were all over the place. I am looking to install headers, don't want to spend too much on them $1500 max with install..what are my options here. And does anyone know someone who can install these headers at a fair price in michigan? (Detroit metro)...i have the ls2 ...thanks, Nick
Headers are pretty simple, standard hand tools and some jack stands and this is definitely something you could do yourself. I'm a fan of Kook's myself, but I would spend the extra money on any of the "premier" brands and do a self install if I was in your position.
How long would something like this take to do myself? (Est)
What about $600 headers is "cheap"?? Not quite $900 or $1100... But $600 isn't cheap. And the obx headers I got had 7/16" flanges.. What looked to be 16ga tubing. Dead on the nose at 1-7/8" primaries.. Great fitment in the car other than barely touching steering shaft.. Excellent welds.. And matched right up to where the factory catback is. So cheap?? Because it may be China made?? So is your computer..cell phone and the electronics in our V's....but not good enough for the exhaust?? Ha..
Cheap would be $340 for thin flanged, thin tubed bare steel pacesetters.
Do you have a stock cat back? If you have magnaflow then it will require some fab work for the headers to mate up to the cat back. I would have done it myself if it wasn't for this.
Plus you need a tune as well, not sure if that is part of your $1500 budget.
I would just expect at least one broken exhaust manifold bolt. It seems pretty common, especially on cars that have had failed motor mounts (a vast majority). In this case, if you can't extract it with the head on, you'll end up pulling the head (or both and doing some "while I'm in here" maintenance/upgrades).
My header install turned in to an expensive DIY, even after getting a deal on a pair of OBX.
OBX - $525
Header wrap - ~$90
Top end rebuild - ~$500
Motor Mounts - $220
Tune - $400
Reused exh gaskets - $0
and a LOT of time.
OBX - $525
Header wrap - ~$90
Motor Mounts - $220
Tune - $400
and a LOT of time.
not sure if this will help anyone... but I cracked all my exhaust manifolds bolts loose while the engine was hot... they all came loose.. the very front bolt on passenger side was already broke.. I had feared someone attempted this and busted the first bolt lol... turns out it was loose too. Also a trick ive always used with rusted or stuck fasteners is to give it a good jolt tightening it... seems to help crack things loose and then work it back and forth slowly untill it comes out.
I did not need O2 extensions with my OBX setup...but the front O2 wires dont have much slack, so for piece of mind it might be good to get 12" extensions (not sure if they do 6"?)
