My 05 CTS V dynod need some input
Just had the caddy dynod today...personally i was hoping over 400 wheel hp but i ended up with 378. Here is the mod list:
LS6 base, 1-3/4 kooks long tubes, K&N cold air, no cats, magnaflow catback, HP tuners, VRX-4 cam, BTR .660 dual valve springs, VR 5/16 hardened push-rods, milling hv oil pump, upgraded trunion rockers, C5R timing chain
I had code for random multiple misfire when i got home. I ordered new magnecor wires when i arrived home. Only thing i can think is the timing may be off :s.
But if it was wouldn't i be setting a code and running like a bag?
Are these numbers normal or should i be making more with my supporting mods?
SAE or STD correction?
Looking at the specs on the cam you might be a little low, but I don't think you'll see 400. Our cars just don't make the hp the Vette's and F-Body's make.
Here is CTSVBiggie's dyno, his cam was spec'ed by EPS. I don't know the specs, but I would think it matches his combo more than an off the shelf cam. His is also a 6.0L and has the 1 7/8 headers. If he didn't crack 400, I wouldn't expect a VRX-4 to do so either. Just my opinion.
Here is bmylez' dyno, he has a 6.0L and a Torquer V2 cam which is larger than a VRX-4. He also has a ported intake. SAE correction would be ~404hp.
Find the situation causing the misfires before you get too down about the dyno. Its just a tool to tune with its not the end all be all yard stick of performance. You can get misfires for anything. Spark issues, if your fueling or MAF tables are off, timing. Bad plugs or wires. Hotter far away is the tuner? He might be able to log it and better determine the cause of the misfires
That is true. I ordered the wires so I hope it fixes it. I haven't informed the tuner yet I will monday and go from there. And I'm from Niagara Falls, tuners in Toronto so 1.5 hour drive not to bad, but if there was any problems he said he would data log it to me
Yea that's why I actually bought the HP tuners stuff. That way if I have an issue I can datalog it and then email it to my tuner. So much easier than trying to explain how the car does something while I'm driving, jerking off, and choking myself st the same time... Just send a log in and ask dafuq is dis? Lol
Not to take this off topic, but do you have some wide open pulls that you've datalogged and wouldn't mind sharing? I'm curious to see what your MAF is doing near redline. I'm seeing a roughly flat trend from 6000-6750, which seems strange to me. Perhaps I've exceeded the capabilities of the stock airbox?
Sorry I though you were the op for a sec infrarev... I believe that the flat line you are seeing could be the computer getting ready to hit the redline for you. Like I said mine is still stock tune so I'll get it up there as good as I can and post an attachment.
the V1 has about a 18-19% drivetrain loss... it took me milled cnc heads with really high compression and a straight vp100 tune to get to 441, and that was a glory pull... hot it was 431. people with similar setups to my current one make almost 40 more rwhp
A** to Mouth? lol I know what you meant but that is what I will forever read when I see atm. So I think about that a lot with all the Texas A&M alum around me with their stickers on their cars.
I'd double check the dyno or your intake I'm putting almost 400 wheel ls2 intake headers exhaust and tune ls2 but my ls6 v made 370 wheel with intake and headers and exhaust
