kooks headers - wideband bung
it looks as though the front (pre-cat) o2 sensors go straight up when installed. i need to also weld in a bung for my wideband. i was going to put it in the same 'position' as the narrowband bung on the drivers side header, but clock it at a different angle.
what do i have to worry about over there to clear with the o2 sensor? should i go inside or outside? does anyone have a good picture of where they put their wideband bung?
Looks like it would be best angled outboard, into that space below the floorpan and inboard of the frame rail.
Here's a pretty good view:
Should be plenty of space there.
so given that i clock it like 45* out from the narrowband sensor, towards the outside, i should be good to go?
did you just take that picture? any chance you could throw a tape measure in there?
Install it on the drivers side, on the inside so the wire comes towards the trans. This how I did mine and works very well.
Did you get a used set? Kook's started making them with the wideband bung already installed. Maybe you got an old set new in box?
I think 45* angled out would be fine, and it sounds like DMM did it angled in, so either way would work. (DMM, how far was yours angled in?)
i was sent these pictures from another V1 guy.
so it sounds like i can go inside OR outside with the bung. i think i'm going to stick with the outside of the pipe, about 45* out from the bung that's already there.
it's not a big deal to get the bung from the AEM wideband welded in, but where does kooks place the wideband bung?
to follow up and not just leave this unfinished...
i never heard back after asking the kooks support for pictures or a location of any second bung that they add in for a wideband so i went ahead and just got it welded in where i thought would be the ideal location, 45* (ish) to the outside of the drivers side header from the narrowband bung. pictures:
now i have to get them sent out to get coated and we'll be on our way to an install. i will update with a few more pictures of how the o2 sensors sit under the car with this configuration. i'm pretty confident it'll be fine how i have it currently. if not, ****.
exactly. then mark an actual good position to put it when the header is on the car and go from there. i still need the wideband so i can't just ditch it.
