Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Makin progress
Old 04-09-2015, 12:46 AM
  #101
Naf
Naf's Avatar
custom made...
I had a certain wheel gap i wanted...
Old 05-18-2015, 05:00 AM
  #102
Naf
Naf's Avatar
We are finally in putty section.
gave them strict instructions to keep the putty to an ABSOLUTE minimum.
Also you may find my front strut braces to help give the front more rigidity...
Hopefully in a few days i will get my car back then its off to the electrician to have my E67 communicate with my car...
Attached Thumbnails Makin progress-img_6305.jpg   Makin progress-img_6306.jpg   Makin progress-img_6307.jpg   Makin progress-img_6308.jpg
Old 05-19-2015, 08:06 AM
  #103
54inches's Avatar
Damn that looks great!
Old 05-19-2015, 10:39 AM
  #104
NIKDSC5's Avatar
I want some pictures of the interior and those seats! How they are mounted etc etc...
Old 05-19-2015, 12:28 PM
  #105
Naf
Naf's Avatar
seats are mounted in the same holes with the sparco slider. 3.3ohms resistor if i am not mistaken for the side airbag delete.
The street seatbelt was tricky, gto seatbelts and accessories. Everythin plugs in. The seatbelt main unit is bolted the the bottom portion of the pillar and the top point is bolted in as well.
Everything has a place you just need to take it all apart to access it
Old 05-19-2015, 01:10 PM
  #106
NIKDSC5's Avatar
What sparco slider? The universal seat base with just the regular sliders? Tell me they make a seat base for our cars and Im going to be pissed! the 09+ version looks similar, but I was unwilling to buy one to find out. Either way, snap some pictures of the seats and bases please and thank you!
Old 05-19-2015, 05:38 PM
  #107
spin2nd's Avatar
Please, please, please document this as best you can and share!
Old 05-25-2015, 06:18 AM
  #108
Naf
Naf's Avatar
Paint has to dry before we can remove from the booth
Old 05-25-2015, 08:46 PM
  #109
54inches's Avatar
Damnit man! Did they remove the stock lip and then add this and weld to the cut?
Any other before photos?
Old 05-25-2015, 09:17 PM
  #110
hefftone's Avatar
Location: Dallas, Ga (2.7 miles from Southeastern Dragway)
DAT *** doe!!!
Old 05-25-2015, 10:04 PM
  #111
Naf
Naf's Avatar
Yes, i now pulled the rear fender out 2" and kept the original lines as much as possible. I didnt want it to look like they were added but the car came this way. When i get back i am goin to check out my wheel clearances and see if i may have coilover setup so i may have better rear end height adjustment.
Old 05-26-2015, 08:54 AM
  #112
NIKDSC5's Avatar
This^
Old 05-26-2015, 08:52 PM
  #113
jcollege's Avatar
Wow wow wow!!!! That looks AMAZING, damn!!!
Old 05-31-2015, 12:54 AM
  #114
54inches's Avatar
Do you have any additional photos.....going this route with my 345s.....
Old 05-31-2015, 02:22 AM
  #115
Naf
Naf's Avatar
You are a brave man...
May i suggest custom rear offset wheels. I made the mistake of goin with ZR1 wheels so i was stuck with the offset, but i couldnt pass on $1500 for set of four shipped to me with hub caps...
Let me know which angles you need and i will try and take the same fotos for you as well...For now browse through my flickr pix...
https://www.flickr.com/photos/691637...posted-public/
MAP offset trailing arm
Penske 2.5" coilover shocks with hyperco springs
custom toe rods
Old 05-31-2015, 11:31 AM
  #116
54inches's Avatar
Thanks bud, I will look at them!
Old 06-06-2015, 11:28 AM
  #117
Naf
Naf's Avatar
Off to the shop to get the new ecm to communicate to the old tech...
Old 06-06-2015, 12:07 PM
  #118
Fweasel's Avatar
Looks mean.
Old 06-06-2015, 02:43 PM
  #119
jcollege's Avatar
Fantastic job man, rims look great on the V as well as the modified fenders.
Old 06-06-2015, 09:16 PM
  #120
Bio248's Avatar
niiiiiiiiiice.
Quick Reply: Makin progress
