Oil Temp near 300
Oil Temp near 300
Driving home yesterday I had the AC on auto on the highway and got an alert and saw my oil temp was near 300 and thn it went away for a few seconds and came back so I turned the AC off to see what would happen and the temps went back down to 230-240.
What gives?
What gives?
It's been awhile since I washed my engine bay area. Would cleaning the engine cause this problem?
1 Post
Ground. Test em with multimeter... wirebrush it all up, add star washer, and test again. Heavymetals had a fix for this a long while back. Seems to only have issues with 04-05.
Aluminum is a **** ground.
The real method would be to measure the voltage drop across the grounds and see which one has the highest voltage across it.
The bolt beneath the hood strut is the biggest culprit (main ground), however, there is the ground on the frame near the alternator and the ones on the rear of the heads, plus the one by the starter motor.
There is also a ground on the drivers side underneath the carpet on the side next to the radio, which is for the dash.
The temp sensor ground reference is from there if I am not mistaken.
The how to:
Using a DVM, connect the negative lead to the battery terminal.
Turn everything on, A/C, lights, radio.
Measure the voltage on the bolt head that is securing the ground terminal.
You want to see less then 25 mv.
If more then that, remove the bolt, wire brush all contact areas to the bolt, terminal and frame.
Add a star washer between the bolt and the terminal, not the terminal and frame.
Use a contact cleaner to clean the threads of the bolt and the mate.
FWIW I re-did all the grounds (with the exception of the one under the driver's side carpet) and they mitigated the problem, but didn't resolve the mis-reporting.
The new ground wire took me literally 10 minutes and has 100% solved the issue.
They are all pretty obvious except the ones behind the heads, but even those are obvious once you locate the bolts.
The one near the starter motor is hidden by the headers.
