Got a bunch of stuff done, question on B&B
So i finally got around to getting a bunch of much needed things done:
-LS7 Clutch kit
-Pacesetter LT headers
-B&B Sport exhaust
-Plugs and wires
I'm not too happy with how quiet the B&B system is, here's a vid:
It's really deep and the drone is just outright ridiculous, now the pipes after the headers (before the x pipe) have resonators on them, i wonder if i get them removed it'll improve the sound and decrease the drone...Thoughts?
-LS7 Clutch kit
-B&B Sport exhaust
-Plugs and wires
sounds like 3" to me Maybe it is me but most drone doesnt bother me ...only when it starts to buildup a drone resonance in the cabin is it too much. If you cant have a normal convo in the cabin while driving thats no bueno
I think with any aftermarket exhaust without a resonator it will drone to some extent.
I had B&B without resonators into some canister style mufflers and I didnt have any crazy drone but I think I may be used to it.
Now I have 2.5" and no resonators, stock exhaust manifolds and an x pipe. I dont get any (to me?) drone on the highway at all. So far I am happy and it was about 350$
It actually drives pretty quiet until I put my foot on the pedal.
http://youtu.be/zX-29lbUCdw
I have the B&B sport as well as highflow cats and the stock manifolds. It is really quiet above 2k rpms but below that the drone is crazy. Especially in higher gears going uphill. I just don't use 6th below 60 mph and it's bearable. Other than 1500-2000 rpm in high gear, I was shocked by how quiet it turned out.
Right I understand, I custom ordered mine with louder mufflers and no resonators and they said "that should be quite loud for a daily driver, nobody has asked for something like this". and it was just very deep.. still sounded good though.
3" vs 2.5" both have a great sound on these ls engines, I have heard some I like more than others but it is all personal preference.
Corsa isnt as loud in my opinion because of the resonator and I believe it is 2.5" but with long tubes and resonator delete the corsa is quite loud.
this is my second V and the first one i spent 1000$ + on the exhaust...Sounded good but I dont think it gained any performance.
Now that im on my second V I decided to go a cheap route and keep the cost down but get a decent sound, thus the muffler delete and res delete all in all I think there is about 500$ wrapped up in the exhaust with labor.
to each is there own I suppose, your B&B sounds same as mine did. which got alot of compliments.
I've seen a few mentions where people have cut the resonators out and just put in straight 3" pipes. They are in the pieces that attach your x-pipe to the individual stock cats or whatever. If you're going straight to headers I could easily see that section of pipe being different.
believe it or not the resonators made zero change for me.. I got them and they ran into the floor board on the driver side. I paid to have them cut out and it changed nothing really.. when you look inside the resonators you could see right through them, never seen a resonator like it before honestly.
Correct, resonators target specific exhaust frequencies. They are not meant to change volume, just control resonance...hence their name. The length of the resonator is main way to control which frequency it cancels/mitigates. You need long resonators for low frequencies.
