Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Not enough bearing clearance
Old 10-14-2014, 09:31 AM
LS BRAVADA's Avatar
Default Not enough bearing clearance
Getting ready to slip the trans in on my LS7 conversion I did my work sheet and I only have .100" clearance for the throw out bearing. My worksheet shows I should have a minimum of .170"
I'm using the GM LS7 kit and katech slave spacer. Spacer measures 1" any thoughts. Thanks guys
Old 10-14-2014, 09:36 AM
voodoochikin04's Avatar
Yes... if youre using a gm ls7 flywheel.. clutch.. pressure plate.. AND a gm ls7 throwout bearing.. you DO NOT use the katech spacer.
Old 10-14-2014, 09:57 AM
bmylez's Avatar
He's using the spacer because he's using the OEM CTS-V slave cylinder. If he took the space out with the V slave...well, then it would be over 1" away.
OP, you need a Corvette slave cylinder and everything should be good.
Old 10-14-2014, 10:36 AM
Well he didnt say in this thread he is using the OEM slave... he says gm ls7 kit.. which sounded to me like he is using the LS7 slave also.
Old 10-14-2014, 10:41 AM
bmylez's Avatar
But that wouldn't make sense, would it? The LS7 slave is approximately the same length as an OEM slave + Katech spacer. If you added the spacer to the LS7 slave, wouldn't it not even be close to fitting? He only needs .070" less, which is weird either way.
Old 10-14-2014, 11:19 AM
well yes.. but he still didnt say, and he could have typed his #'s wrong.. Just sayin
Old 10-14-2014, 12:36 PM
LS BRAVADA's Avatar
Yes I'm using the stock CTS-V slave. Sorry for the confusion. Either way it's still weird. I can always chuck this spacer in my lathe and face off .070"
Old 10-14-2014, 04:13 PM
gtistile's Avatar
I did a Mcleod RXT with the LS7 slave very recently and if I remember correctly I had the same exact measurements. There is no "buy this and buy that and you'll be fine" with these cars. Something is funky with the length of our bell housing Or something which causes all these clutch issues on these cars
Old 10-14-2014, 04:23 PM
bmylez's Avatar
So then what did you do, RJ?
Old 10-14-2014, 07:05 PM
LS BRAVADA's Avatar
Ok. Tonight I measured everything a hundred times and I still come up with only .100" clearance. I chucked the katech spacer in my heavy 10 and faced off .060" the same thickness as one of ticks slave shims he offers. If it don't work then I can always slap a shim in and see what that does. I should of just did an automatic conversion.
Old 10-14-2014, 09:39 PM
Why didn't you use an LS7 slave?
Old 10-15-2014, 05:15 AM
LS BRAVADA's Avatar
Cuz I used the stock one with the katech spacer
Old 10-19-2014, 11:08 PM
Motown Cad's Avatar
Bravada, How did it turn out?
Old 10-20-2014, 02:26 AM
LS BRAVADA's Avatar
It seems like it's gonna work just fine. I got everything back together minus the drive shaft. (I got my mega kit from CS and everything is installed minus the front diff bushing). When its in gear I can't turn the output shaft, push on the clutch and I can turn it.
Old 10-22-2014, 07:51 PM
Motown Cad's Avatar
Let us know ok. I'm starting mine this weekend. Thanks.
Old 10-23-2014, 09:32 AM
LS BRAVADA's Avatar
So far it seems ok. Still on jack stands. Got starter and cats back on. Started it without the driveshaft and exhaust. VVVROOM
Old 10-23-2014, 06:29 PM
Aaron Thomas's Avatar
Neighbor's always love the start up with open headers or no mufflers. My LS7 clutch has been collecting dust in the garage waiting to go in and it has finally cooled down enough to actually work in the garage, i am all out of excuses. How many hours total did it take to replace? I went with the LS7 slave and have the tick shims, so crossing my fingers for no delays .
Old 10-23-2014, 07:40 PM
LS BRAVADA's Avatar
I'm doing all my mounts, bushings, fluid changes, clutch conversion , struts, shocks, etc, etc. going on 3 weeks this Saturday. No hurry what so ever, and my 7 year old girl is under thare with me. Been waiting on differential bushing for a week, it's on back order. Hardest part was sliding the trans back in. Those crappy plastic line up tool lets the disk drop a bit with gravity. I should of lifted up on it a bit to compensate for this and it would of went right in.
Old 10-23-2014, 09:24 PM
I have a 95a revshift diff bushing that could leave in the mail tomorrow if your were inclined.
Old 10-24-2014, 06:06 PM
LS BRAVADA's Avatar
It came today. Got it in and just need to decide on this driveshaft thing
Quick Reply: Not enough bearing clearance
