Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
help, I'm in motor mount hell.
Old 10-20-2014, 12:42 PM
isis's Avatar
Originally Posted by LS BRAVADA
This stuff is hard like metal. They say it can be drilled and tapped
Yep, JB Weld
Old 10-21-2014, 12:03 PM
dead civic's Avatar
Originally Posted by isis
Yep, JB Weld
yeap. i fixed part of a tranny once with JB Weld. It works great.
Old 10-21-2014, 02:47 PM
voodoochikin04's Avatar
I cross threaded about 1/2" of that same bolt hole. My fix was this: I hit the tip of the bolt on the grinder so its more rounded and helped center it better. Then I used a spade bit for drilling holes in wood, that was slightly larger than my bolt. I drilled into the aluminum just past the bad threads. Bolt threaded in just fine then.
Old 10-21-2014, 07:22 PM
1BADCTS's Avatar
Use that two part putty stuff that sets up hard like metal and leave a stud sticking out then put a nut on the end.
Of the 'ghetto' options available, I think you're spot on. I'd trust that over tapping the JB Weld or any other product.
Old 10-21-2014, 08:42 PM
ryridesmotox's Avatar
Use it as an opportunity to convince the wife that you need a 454LSX block.
Old 10-22-2014, 06:30 PM
hefftone's Avatar
Location: Dallas, Ga (2.7 miles from Southeastern Dragway)
Default Losing my cool.
I am hating this car right now. I swear its fighting me tooth and nail to keep from going back together. Its worse than my BMW E36 by a longshot.
Ok....Im just unfamiliar with this car, and f***ing sick of working on it in my driveway....not enough time, not enough light....and I'm two bolts away from being done!!!! end rant.
The problem I am having is getting the exhaust to bolt to the catalytic. I need some play in the exhaust, I've got nothing to work with. The drivers hardware is froze up really hard...I think If I got that lose I could push the exhaust rearward just about a 1/2" would probably get it. I need the flange piece to slide over the stud (the other stud was replaced with a bolt). Not sure if the whole exhaust is magnaflow or just the mufflers.
**** has me so ill.
Old 10-22-2014, 06:42 PM
scotty2000ss's Avatar
I feel your pain bro. All I can say is you'll eventually get it done and the accomplishment feels great. Hang in there dude.
Old 10-22-2014, 07:06 PM
hefftone's Avatar
I went back down....I'm almost there. Busting the driverside loose at the Cat flange made all the difference in the world.. I guess that PB Blaster had to soak in for about 20 minutes...Just got to find the one nut that got displaced when I started kicking and throwing **** (prior to previous post).
Yes, I'm a thrower. Might sound like a twelve year old but it helps me get by!
Its so frustrating, how tight everything is...I put the cat on about 5 different times tonight...then I had to take it off again to plug in the forward O2 sensor plug. Really GM?!?!? You could'nt make the vehicle harness have like 2 inches of slack...Cheese and rice....
Almost there..... Serenity Now!!!
Old 10-22-2014, 09:13 PM
isis's Avatar
Don't post angry. Penetrating fluid can take hours. Spray it the day before a few times whenever possible. You'll get it
Quick Reply: help, I'm in motor mount hell.
