Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
No sound from radio or door chimes
Old 10-29-2014, 11:24 AM
demang's Avatar
Default No sound from radio or door chimes
I did some searching and found it might be my stock amp. Does anyone have one they want to sell? Has anyone had this proble and had a souloution that was not the stock amp?
Old 10-30-2014, 03:06 AM
Vcaddy71's Avatar
I worked in car audio for a long time... Rarely do head units(factory or aftermarket) completely go out. They typically will start to crackle and sound like **** but will still work. Amp is most likely solution. Check fuse and make sure amp is still getting power and if you can try to verify amp turn on is still receiving power.
Quick Reply: No sound from radio or door chimes
