Freezing Temp Affect Valve Springs Life?
My car will live in the garage this winter, as it has the past 3. I may buy this for my DD:
http://www.amazon.com/Kats-15200-Dip.../dp/B000BO74DG
It might just be dogma on my part, but I've always let my engines idle for at least a few minutes when it's cold out to avoid excessive wear due to low temps. I figure it gives my seat heaters, defroster, etc. time to warm up, a little bit of time to get oil circulated. Might not be necessary with modern engines, but it couldn't hurt.
Whatever this is worth, I got this response from Comp Cam USA:
"we do not build our springs in house so we do not have the metallurgy process at hand and that most of our springs are supplied by some of the same manufacturers that the "automakers" use for their valve springs and leave it at that. "
Interesting info. This might give some insight on the durability of these springs if they are used within spec limit.
