FYI: OEM transmissions mount
In what way did you get your caddy back, LS Bravada? I'm thinking about going back to the factory tranny mount on mine - I have a poly tranny mount in there right now. With the poly motor mounts AND poly tranny mount I have a VERY rigid engine/drivetrain and I'm actually looking for a way to "soften" it a bit.
Just as an FYI ls1, I'm running creative steel mounts and a DSS one piece carbon fiber driveshaft. And it is not a tuning fork...
I think a lot of your issues may be isolated to you or your high mileage v. I don't think every v is the same so each will respond differently to certain mods.
I'm excited your OEM mount made your v better. But there are quite a few people that would argue the aftermarket vs OEM.
I wouldn't be opposed into throwing a new OEM mount in to see what it does to my car. Im not going to buy one though so I doubt it will happen.
And maybe it is me. If I spend 1400 on a driveshaft I expect it to be smooth.
I'm sure you checked but what was your angular differences bet ween both CVs. To my knowledge any angle on the front joint must be equal on the rear to equal a pure shaft and not an out of round rotation.
I'm sure you knew that and checked it though
https://ls1tech.com/forums/cadillac-...t-options.html
I have UMIs which I think play more of a role in this than the your CS mounts do. I dragged everyone through that conversation to so I'll spare you the details....
