What causes rear ends to blow?
After reading alot, it seems the rear ends give out alot on these cars. What's the part which gives out? Or is it the wheel hop which messes things up?
I have a '06 with upgraded creative steel axles, does that help to keep my rear end from blowing up?
Wheelhop causes stresses in the diff case that exceed its strength.
Even eliminating WH will not 100% protect the diff if you do too many burnouts, but it will help.
As mentioned, going 8.8"/9" seems to be the only real "cure."
Blame the GM bean counters.
If you do the work and look at the GETRAG specifications for the diff, it is underrated for the torque the LS motors are capable of.
The big reason why they got away with it is no one died, or the # that died wasn't big enough, unlike the ignition switches.
Update:
Looks like all the tech specs on the GETRAG 645 have been removed from their website.
The CTS-V FAQ's just lists an old link that doesn't work.
I will search my old HD's as I think I downloaded the specs at one time.
Update:
If the axles are plugged in to a Getrag diff.....they aren't from us. We only sell axles for the 8.8 swap.
True: GM could've picked a different diff from the Getrag catalog that would have stood up to the LS engines, but would have cost more.
1 Post
You could bulletproof the case, and then spend your time snapping stock axles every run. You could bulletproof the axles, and snap the case at the ears.
You'd need a full swap to be able to hop and NOT break anything.
Have hopped bad quite a few times when it was wet out- get off the gas, and learn what causes it on your car. In my '06 it's only a problem if I were to try to do a standing burn out or too much gas when wet out.
If you don't hop it, you're probably fine long term. 115k now on my stock diff. I wouldn't replace stuff if you're not abusing it.
I am able to buy a diff out of a t-bird for a good price. what else do i need from u guys to complete the swap?
