Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
04 cts v racetronix pump wiring?
Old 02-11-2015, 02:53 PM
blkbird2kta's Avatar
Default 04 cts v racetronix pump wiring?
Im installing a racetronix fuel pump kit in a 04. The pump came with a new harness plug for the new pump. The old harness that goes from the pump to the hat has a wire going to the fpr. The new harness doesn't. I assume I need that wire going to the fpr. Is it missing or not needed? Does anyone have any experience with this and what did you do? Getting ahold of racetronix is a pita by the way
Old 02-11-2015, 05:46 PM
CTS-V Shifter Sales
07CTS-V's Avatar
I have mine pulled right now. I don't have a wire going to the regulator. There are two wires going to the fuel level sensor. Post pics.
Old 02-11-2015, 05:59 PM
vmapper's Avatar
what are we missing here.
The following statement makes no sense
the Fuel Pressure Regulator (FPR?), part of the bucket assembly, is a pressure spring setup... no wires.
as mentioned by 07CTS, you will have a level wire... but that is nothing to do with the Hot Wire Kit. That kit is 'super' easy... im sorta scared these are questions at all...
Old 02-11-2015, 07:18 PM
qqqqball's Avatar
The 04 has a black ground wire going to the FPR, it is a pressure spring, but it is in there for a ESD precaution. I noticed my brothers 07 didnt have it. I just wired it to the negative side of the pump.
What blkbrd is talking about is a 28 gauge wire that is factory spliced into the negative side of the pump. It does nothing more than ground the FPR, it is a ground strap so when you ran out of gas it would reduce the risk of a spark. Older FPR are metal springs on a metal cylinder wrapped in plastic.
Sorry no pics, I will have the Pump out this weekend.
Old 02-11-2015, 08:34 PM
raven154's Avatar
What Qball said. My 04 has the same.
Old 02-12-2015, 08:19 AM
Thanks qqqball. I found out it was a ground after I posted this. Ill just ground make a wire and ground it like it was stock.
Thanks for the reply.
Old 02-12-2015, 08:33 PM
vmapper's Avatar
Yes, this.
However, it is not going to the FPR from what I remember (it might be 'near it...but) it is, as mentioned just for 'static'. Based on the discussion, that is why I was confused.
Fuel passes through that tiny jet to push on the blue flap to fill the bucket.
Attached Thumbnails 04 cts v racetronix pump wiring?-.jpg   04 cts v racetronix pump wiring?-this2.jpg
Old 02-12-2015, 09:15 PM
jclayc's Avatar
when I removed & bypassed the internal FPR from my 05 to run an external FPR, I just clipped that ground wire and left it alone. mistake?
Old 02-15-2015, 03:16 PM
vmapper's Avatar
no mistake. I run an after Rail regulator for a return style setup. One siphons from one side of the tank to the other visa versa. Keep the levels even on this saddle style tank.
Old 02-15-2015, 04:44 PM
raven154's Avatar
So who has done the hot wire install? I did mine last night but instead of trying to get it on an almost impossible alternator stud, I just ran it straight to the battery. That cable runs straight from the battery to the alternator so I figured it was just about as good. They supplied two battery bolts with the extra bolt in the end to add accessories. I used one on the positive for the pump harness and I'm using the other on the negative so I can run a daisy chain to the grounds.
Old 02-15-2015, 06:15 PM
qqqqball's Avatar
I did, but it is on the alternator, I did when I was putting headers on, so it was easy. On my T-type I did a very similar kit and found that hooking it up the battery under mid-high rpm stabbing the throttle dipped the amps, but I cannot see it being a problem, it quickly recovered.
Old 02-16-2015, 10:39 PM
vmapper's Avatar
Battery is fine.
I have a habit of upgrading and adding grounds from the ole stereo days.. so usually have 8 Ga. running around.
Quick Reply: 04 cts v racetronix pump wiring?
