Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
V2 guys with EFI Live.
Old 02-18-2015, 04:37 PM
Pray's Avatar
Default V2 guys with EFI Live.
What PID are you all running for VSS? The standard E67 Pid I use for my 07' does not work and then it does that stupid million miles a second sampling. I just found SAE VSS under Conditions, is this the correct one? Didn't see it when I had the car. Also, do you all log IAT 2. I noticed there is no way to tune for it (unless I missed it) so does it really matter to log it. To me it seems critical to timing. You can still have a heat soaked blower and hot IAT 2 readings in 50* weather and have the ECM adding 5* timing to a hot blower.
Old 02-18-2015, 06:05 PM
serik21's Avatar
If it's a 07 you have a V1 not v2
Old 02-18-2015, 06:08 PM
Pray's Avatar
Riiiiight, I understand that. I used the same PID's and Dashboard that I use on my 07' on my buddies 11'. I got the difference between V1's and V2's.
Quick Reply: V2 guys with EFI Live.
