Recaro Seats - Gen I
Alas, I have been waiting for someone here to figure it out but the solution has not arrived Other than keeping the stock sensor or course. So maybe when i switch out my seats some day I will solve this problem, but due to my procrastination and general laziness....don't hold your breathe!
Didn't you wish you had removed the sensor before getting rid of your old seats? I got one I can sell ya!
To Ls1247 point I have not seen anyone mount the seat belts to the B-pillar......?
I have seen it go to the rear seat belt mounts, or like jclayc, a full on cage.
Do a search with keyword seats in title only cts-v section OP
It has been done several times before. They have also mounted the seat belt on the B pillar. They mounted a piece of steel behind the pillar. Some had the passenger sensor installed into the seat, for side airbags they had a resistors installed. I had a ton of threads saved, but I lost a lot of my data.
Yes, I have resolved the main four airbag codes (F+R, L+R) - leaving just the the PPS warning. This shows you the wiring for how to do the main two under the seats. http://www.cadillacforums.com/forums...ml#post3175348 Taking care of the rear curtain bags is the same resistor process as in that post. That just leaves the light triggered by the PPS and, since the post above, I've also removed the steering wheel airbag but haven't worried about turning off its code.
My goal with the PPS would be to get the light to turn off, not have the pps sense people and turn the airbag on and off. Unlike the other sensors which turn off the light by sensing the resistance of the bag, I believe the pps circuit puts through a tiny bit of voltage that will get the light to turn off.
How much for the PPS bladder/wire?
I'll have to make use of those resistors when I get home finally and turn off the light/warning. I have an 04 so no passenger sensor. As for bolting belts to the pillars, I've seen it discussed but never have seen pictures other than that single photo. For my Sparcos I have 6 points attached to the roll bar but a street 3 point option would be nice.
Didn't mean to stir up a hornets nest. What used to be a simple thing back in the days of swapping out seats between cars has now turned into a BIG fiasco. I didn't even think about front/side airbags, different seat belt mounts, etc., etc. But I do thank everyone for their input.
Regards,
George
Regards,
George
