Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Loss of power
Old 04-13-2015, 01:39 AM
blkgagt94's Avatar
Default Loss of power
So I finally drove my car after being stored battery died last summer I recently did a cam intake exhaust on my 2005 cts v an I drove it down the street after it was idling an I started out in 1st cruised then I stomped on it got loud exhaust wise but had no power at al like it a miss on all the cylinders but if I drive normal an not wot it drives fine had it tuned after cam but idk how good it is
Old 04-13-2015, 02:05 AM
serik21's Avatar
Double check the connectors on your coil packs make sure the main connectors are snug clicked In I'm sure you are only running on 4 cylinders
Old 04-13-2015, 02:39 AM
itsslow98's Avatar
Might be bad fuel if its sat for almost a year without stabilizer.
Old 04-13-2015, 03:33 AM
blkgagt94's Avatar
Sat for almost 6 months no stabilzer but I think I had the same problem after cam install but not that bad I'll check plugs an small stuff clean
Maf
Old 04-14-2015, 01:52 AM
Naf
Naf's Avatar
This isnt Fast and Loud, you cant just start a car idle it and spank it with perfect results... You have to run the car for a while and drive it easily through the rpm range and get it tuned so it may run properly...
If you get it tuned it will run properly...
Old 04-14-2015, 02:13 AM
Vcaddy71's Avatar
I had a plug wire go bad and did the same thing... ran great until WOT and fell flat on it's face
Old 04-14-2015, 06:13 PM
Motown Cad's Avatar
Sounds like a coil pack, spark plug or wire. Pull codes at autozone and proceed.
Old 04-15-2015, 12:59 AM
Naf
Naf's Avatar
He didnt mention tune...
His idle would be crap and it would surge all the time if he had an ignition issue...
Old 04-15-2015, 01:45 AM
itsslow98's Avatar
I highlighted your oversight on calling someone out.
Old 04-15-2015, 03:12 AM
blkgagt94's Avatar
Thanks an yea I had a tune not my first rodeo
Old 04-15-2015, 04:02 AM
Naf
Naf's Avatar
AH he cheated and edited it...
Old 04-15-2015, 02:22 PM
vmapper's Avatar
Could be many things, including and not limited to:
-Broken Valve Spring? (Cam change, maybe you have duals in there now)
-A poorly done ECM Calibration
If you can get a scan to see if any misfires have been detected.
Do the usual.. check plugs, wires coils.
Lift valve covers and visually inspect springs.
Old 04-16-2015, 12:51 AM
Naf
Naf's Avatar
could also be just bad fuel with water in it...
it did sit for a long time...
Old 04-16-2015, 12:07 PM
vmapper's Avatar
yes. could also be.
Old 04-16-2015, 09:36 PM
blkgagt94's Avatar
So I recharged battery no lights on an drives fine lol must been ecu being weird from sitting an not being charged
Old 04-17-2015, 09:47 AM
ls1247's Avatar
Mine didn't run worth a crap after leaving the battery disconnected for a week. It acted like it had to relearn everything and one of the injectors was making some racket. After a few minutes, it smoothed right out.
Old 04-17-2015, 12:17 PM
vmapper's Avatar
what does that even mean? No Lights on? and it instantly drove fine? Did you drive (start / stop /start engine ) a few time?
ECMs do not go 'weird'.
Old 04-17-2015, 06:05 PM
isis's Avatar
They don't go weird, but these cars HATE low voltage. All kinds of gremlins show up if your battery gets low from sitting or parasitic drain. Maybe that's what he means.
Old 04-17-2015, 06:44 PM
ls1247's Avatar
bad grounds have been the source of more of the electrical evilness I've encountered in my 3+ decades of working on cars.
Old 04-17-2015, 10:01 PM
MN_V's Avatar
Very true. When I had a battery taking a dump on me and keeping voltage low, the AC would not shut off as well as a couple other weird things. If I could get it to turn off, it would always revert to being on when re-started.
Quick Reply: Loss of power
