newb ? lowering
newb ? lowering
hello
older guy here (fifties), been doing some reading here...(great site),just obtained a 05 with mods and love it..... bottom line I want to lower....I understand about the spacers and looking to go with h&r's......but in reading of some past posts....I see where some say the stock tires rub and some don't, my main objective is to least lower the rear to level the car out.....has anyone just lowered the rear to do so? I don't want to buy whole set of springs and just use the rears....so thinking of spacers and then cutting the springs in rear, but will buy springs if have to
perfect world I want to do all the way around with h&r's....but paranoid on rubbing up front (I am sure I am at stock level up front, but there aint a lot of room up there with naked eye) car is not daily driver (just play toy) any input is much appreciated and sorry I never found a post about just rear lowering or a iron clad answer that says stock tires / rims will not rub with h&r's all the way around with spacers.....bottom line I don't want to open other doors with problems etc....
thanks in advance
thanks in advance
Cutting the springs will shorten (no pun intended) their life.
Alternatively, you can do the mighty mouse route which is the more frugal way or you can do the Ground Control kit.
I'm at about 3/4" lower and have no rubbing issues, but I also have stiffer springs as part of the Ground Control kit. It's adjustable, too, with the spanner wrench that's provided.
Going 1" or lower, and you'll begin to experience rubbing depending on tire size, if you're doing to sharp turning, etc.
Car looks so-o much better even with a very modest amount of lowering.
Just my $0.02.
Just my $0.02.
that's because the H&R springs are much too soft. you're going to be better off with a set of coilovers and some proper spring rates than you will with a set of drop springs.
it also doesn't hurt to just roll your fenders and run a bit more aggressive of an alignment.
thanks for replies.....been doing a little homework / reading / thinking etc....and I think I am going to go with the d2 coilovers......the place I am in contact to purchase, did mention doing them I will throw a code/engine light
question is....and it may be a answer here in searching and if so sorry.....but is that the case and how do I not have the engine light if go to the d2's or get off? and any other things that I need to know in doing these I am all ears in regards to other things to correct etc..... thanks in advance.....any input very much appreciated
ps: I know the light wont be no biggie (only visual I guess) but prefer to not look at all the time be it blinking or staying on
problem I have and I might have to break out tape measure and take pics etc...my front looks lower (less wheel gap) then what I see on here (pics) of stock 05 v's on front and as mentioned in first question.... a possibility for me is just bring down rear a bit to level....for sure doing that at least would be way more better on the $$ and i would be satisfied at least for now and maybe coil overs in the future.....for the record, the rear of mine looks like most i see on here that are stock
you got me thinking and don't mind the ignorance....if just use the mm spacers (nothing else / leave stock)...will that for sure bring rear down a approx. amt? or can it vary or maybe it will or maybe it wont? or anyone out there that just did mm spacers to level and bring rear down?
Or maybe just pull the shocks out and see where the car sits on just the springs? Obviously don't drive it like that.
You should take two sets of measurements. Measure from the center of the wheel straight up to the fender on all four corners. First set of measurements should be after the car sits overnight, the second set should be after you drive around the block a few times.
It sounds like someone may have lowered your car with out using spacers on the shocks. That would explain why you think the front looks lower than normal and your rear end is jacked up.
For reference on my car:
Stock suspension @95k miles, FL 14.4", FR 14.75", RL 14.875", RR 15"
Now on KWV3 coilovers I am at Front 13.5", rear 13.75"
I'm running 255/45/18 Hankook Ventus V12 front and rear and they just barely rub on the front wheel well liner, and once on the fender when I was turning into a parking lot too fast.
Here you go.
Stock suspension @ 96k miles, ride height was FL 14.4", FR 14.75", RL 14.875", RR 15"
With KWV3 coilovers I had the front set to 13.5", and rear 13.75. These pictures have 245/45/18 Pilot Super Sports, but as I mentioned, I'm not running 255/45/18 Hankook Ventus V12.
It's not slammed, but I daily drive it year round in Wisconsin, so I still need some clearance for snow.
how did this turn out?
if you just want to lower a little or just lower the rear there is no sense in coil overs and probably no sense in even buying springs. you already own a pair that are working fine, and a minor trim (with shock relocation) will get you exactly what you are looking for.
