Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
clutch time... want to reuse ls7 slave and flywheel
Old 06-27-2015, 02:00 PM
RADEoN's Avatar
Default clutch time... want to reuse ls7 slave and flywheel
What are my options here? I'd really like to reuse my brand new flywheel and slave cylinder if possible.
Can I just put a monster stage 3 c6 clutch setup in this bitch?
Old 06-28-2015, 09:17 AM
raven154's Avatar
You might ask Monster but as far as I know all Monster clutches use a flat flywheel unlike the recessed LS7 flywheel. The only one I know that will bolt to a stock LS7 flywheel is a SPEC LS7 setup, I have one laying around, but I all I've had was problems with the SPEC pressure plate. It just wouldn't let you shift over 4k or so rpm so I would stay away from them.
Old 06-29-2015, 09:47 AM
SNLPerformance's Avatar
More than likely you can use the stock slave, but if you want to double check give us a call and my guys will make sure you don't need to do something extra. (817-750-2000)
Old 06-29-2015, 02:24 PM
BudRacing's Avatar
Is a C6 clutch replacement not an option? Sounds like an inexpensive replacement that you know will fit. How many miles did you get out of this last setup?
Quick Reply: clutch time... want to reuse ls7 slave and flywheel
