CS 8.8 setup hitting exhaust
Just picked the car up recently and noticed under heavy acceleration and mild turning, there is a vibration coming from the trans tunnel. I threw the car up on stands and noticed the DSS two piece is hitting the exhaust at the coupler. It has pretty much dented the pipes. Would this be a sign of the trans mount going bad?
If it is the OEM Transmission mount, make sure you are able to fit at least a pinky between the center safety pin of the transmission mount and the bottom of the transmission.
When they reinstalled the exhaust did they not get the angle right? There is quite a bit of up/down positioning you can do depending on where you are holding the pipes while you clamp everything down. At the end of the day a dimpled exhaust pipe for clearance is not a bad thing.
