Heads, cam, and E-force build
Plans right now are to do he following:
-A set of PRC Stage 1 6.0L CNC Ported Heads (317 casting) w/ PRC dual springs & Ti retainers
-LS9 headgaskets
-Recommended cam for supercharger setup (daily driven)
-LS7 lifters
-Upgraded pushrods
-Trunion upgrade for rockers
-E-force setup with LS2 style TB (size?)
-What MAF setup to use?
-probably replace the timing chain/gears and oil pump while I have it apart.
-fuel system will get addressed at the same time and I'm sure the clutch shortly after...
Any recommendations?
-LS9 headgaskets
-LS7 lifters
-Upgraded pushrods
What are my options for a throttle body?
Also what exactly about the ls6 valley cover interferes with the e-force? The vent tube?
. Also what exactly about the ls6 valley cover interferes with the e-force? The vent tube?
Yes. The unfortunate thing is this means you lose the oil separator. Get a good catch can.
You can use the standard LS1, LQ4/9, or LM7 valley cover. I would take it to machine shop and have it shaved down a bit and you'll have to drill/countersink the valley for the flush bolts. Also, use anti seize on the valley bolts as the inverted hex strips out very easily.
Your lone choice for a throttle body is an LS2 unit. The LS3 and later LS7 articulate in the opposite direction and will wreak havoc on the PCM unless you zero out every throttle body DTC, which is a really bad idea.
Get a brand new throttle body from GM, there have been quite a few people that have been screwed over for a few hundred $ in their attempt to save $100 or less.
I really wish you would stop pushing this garbage.
Ballpark cost
Heads, cam, springs, pushrods, lifters, roller rockers, head studs oil pump, timing chain set, gaskets, balancer approx 3300
8.8 rear upgrade with full axles approx 2750
E-force and parts approx 5000
Fuel system maybe 1000
Hptuner pro 650
Pics to follow
Hptuner pro 650
Pics to follow
Going from memory on the 8.8 kit, Black Friday price on the kit, bought a new carrier, bearings, gears, used case.
Stock 150k mile bottom end. Will be building a new short block next winter if I haven't blown this one up by then, lol.
Small note: I just got done doing a lifter replacement this week and I noticed your power steering pump is just hangin out. The only thing holding it up is the power steering line. Not sure how healthy it is to support the weight. I leaned mine against the block, if you care.
Looking at almost $400 for a new throttle body which is I think 90mm? Any hp to be gained to just go ahead and get a nick Williams 102mm now? I've seen a few sell for $500 in the classifieds NIB.
Keep in mind you're putting a 2.3 liter supercharger on a 5.7 liter engine; you're far from even scratching the surface of its capabilities.
Looks like you're off to a good start from the pics!
