New to the Ls world and need some info.
4.8's are fun little engines too but with above I wouldnt spend any coin on aftermarket heads etc. Cam only? Sure why not. Something like a 218/222 XE lobe comp with PAC 1218 springs, new pushrods and some long tube headers + decent exhaust will be a stout little package. Leave stock heads, intake, throttle body, ecm etc etc etc but add a decent stall if running auto.
Then build a bigger cube engine while driving this one to swap later if you find the power isnt enough for you.
Id build an NA 4.8.... Would be fun.
BUT, it would be a low torque, high rpm sleeper. Ported 243's and the right cam and intake and you have yourself a 7800 rpm screamer.
Great and fun for a light car, not so much for a heavy truck.
But with boost those 4.8's are animals.
by the noise of it i should just find a 6L or a ls3, also should i stay away from dod engines. whats better 53 tooth or 24 tooth?
4.8 suuupppeerrr strong fun engine.. Yes notba "huge" HP engine but yeah 400 definitely achievable. I think they are base at 280ish?? Boost it.. For half the price of a Na build.. 8 psi, good tune very streetable 475-500
