Canadian Members We never leave because we have The Beer Store
New to the Ls world and need some info.
Old 03-12-2016, 07:41 PM
skidder07's Avatar
Default New to the Ls world and need some info.
I plan on swapping a ls motor in my 2002 Gmc Sonoma. I have already did the pre fab work to fit the engine between the frame rails. Also have a holley oil pan. I have a 4.8l sitting around. Not sure if i should use it or not. i was thinking about a 5.3l or 6l with trick flow top end kit and a fast intake. Any help would be great.
Old 03-12-2016, 07:55 PM
madmike9396's Avatar
Umm what exactly is the question?
Old 03-12-2016, 07:58 PM
skidder07's Avatar
should i build the 4.8l or am i wasting my money and time
Old 03-12-2016, 08:07 PM
4.8 can be stout ! What is your end goal / budget?
Old 03-12-2016, 08:09 PM
skidder07's Avatar
400hp or so. thats what im hoping for
Old 03-12-2016, 08:15 PM
Yes a head cam 4.8 will easily make 400+hp. Manual or auto ?
Old 03-12-2016, 08:17 PM
skidder07's Avatar
want a t56 behind it. would a trick flow top end kit work well?
Old 03-12-2016, 08:25 PM
Honestly Id get in touch with a vendor here. They will be able to give you information on what you will need for your goal. Such as what heads cam specs etc etc
Texas speed performance
(SRD) Smallwood Racing Development
Tony mamo Mamo motorsports
Are a few that come to mind
Old 03-12-2016, 08:34 PM
skidder07's Avatar
thanks
Old 03-12-2016, 09:26 PM
tfi racing's Avatar
Maybe not a waste,but you likely won't be happy with the 4.8. Sell it off and put the cash towards a 6.0,putting $4k worth of heads,cam and intake on a 4.8 to barely out hp a bigger motor is not the best idea...
Old 03-13-2016, 08:23 AM
So you saying a H/C/I 4.8 is going to barely out hp a stock 6.0 ?
Old 03-13-2016, 08:44 AM
transamtom's Avatar
Do a search for 4.8L on Hotrod.com.
They thought they had a 5.3 and they wanted to see how much spray or boost it could take before it went boom.
They couldn't kill it and made nearly 1100 hp on the dyno before they showed mercy and did a tear down.
They found out it was a little 4.8L.
Old 03-13-2016, 08:48 AM
transamtom's Avatar
I would just put here in and get a turbo or NO2 kit and have fun till it pops then go looking for a 6L or 6.2L. JMHO
Old 03-13-2016, 09:05 AM
skidder07's Avatar
That's why I ask if it's a waste or not. I got the engine for free and use it for test fitting in my truck.
Old 03-13-2016, 12:25 PM
LETZRIDE's Avatar
put it in...everyone has 5.3s, 5.7s, and 6.0L - it was free and they can make power and it's different
Old 03-13-2016, 02:13 PM
It will make the power you want to achieve.
That **** was free ???
Id slap some heads and cam on it and roll. It will be a peppy Lil motor
Old 03-13-2016, 08:29 PM
tfi racing's Avatar
Looks like I'm the idiot here,$3100 USD for the Trick Flow Top End Kit and $900 USD for a Fast intake at Summit,makes perfect sense to bolt those parts on a free 4.8,if the OP got those parts for free,please share with us how that happened,we all would like a set...
Old 03-13-2016, 08:40 PM
Orange Juice's Avatar
If you are going to spend $4000 on top end, cam and intake. I would spend the money for the cubic inches and do it once.
Old 03-14-2016, 02:58 PM
LETZRIDE's Avatar
why is it costing $4000 to pull 400hp out of an engine that already has 290hp to begin with? A set of headers, a well spec'd real aggressive cam and an intake with a solid tune should more than have you in that range
The 4.8L heads don't need to be touched for that hp goal at all. Aside from your supporting mods for your cam (valve springs etc.)
Old 03-14-2016, 03:14 PM
transamtom's Avatar
I would get a cam and springs leave the heads and intake stock and put the money into a good NO2 kit and spray the hell out of it.
Quick Reply: New to the Ls world and need some info.
