Canadian Members We never leave because we have The Beer Store
02 Camaro
Old 02-01-2008, 09:46 PM
9-Second Club
MADSCI's Avatar
Default 02 Camaro
2002 B4C (Remember these cars are nothing special!) CAMARO 11.90`s @ 113 mph
102000 MILES,420 RWHP,LQ4 364 CUBE IRON BLOCK, HIGH FLOW LID,LS6 INTAKE, PORTED THROTTLE BODY, FULLY PORTED HEADS 2.100 X 1.60 STAINLESS VALVES, PATRIOT GOLD SPRINGS, TITANIUM RETAINERS, COMP CAMS CHROME MOLY PUSH RODS, ROLLMASTER DOUBLE ROLLER TIMING CHAIN, COMP CAMS 232/234 CAM,PORTED LS6 OIL PUMP,ARP HEAD BOLTS, FEL PRO HEAD GASKETS, NEW OIL PAN,MSD WIRES, LONG TUBE HEADDERS, CUSTOM 3" Y PIPE WITH HIGH FLOW CATS, FLOWMASTER CAT BACK, TH 350, BMR TRANS CROSSMEMBER, TCS 3800 CONVERTOR,B&M PRO RATCHET SHIFTER, 3" SEAMLESS CHROME MOLY DRIVE SHAFT, CUSTOM SUBFRAME CONNECTORS, UMI LOWER CONTROL ARMS, UMI RELOCATION BRACKETS, UMI ADJUSTABLE PANHARD, UMI AJUSTABLE TUNNEL MOUNT TORQUE ARM WITH DRIVE SHAFT LOOP, ALUMINUM GIRDLE REAR END COVER, 4.10 GEARS, ARP WHEELS STUDS, QA1 R SERIES ADJUSTABLE FRONT STRUTS WITH 275LB SPRINGS, COMP ENG REAR ADJUSTABLE DRAG SHOCKS, REAR EIBACH SPRINGS, RACETRONIX 225LPH FUEL PUMP WITH HOT WIRE HARNESS, NEW HEADLINER, NEW BRAKES,NEW BATTERY, NEW PAINT, WELD DRAG LITES 15X3 WITH 185/SR 15 TIRES AND 15X10 WITH 275/60/15 ET DRAG RADIALS , FLORIDA CAR NEVER DRIVEN IN ANY WINTERS NORTH OF FLORIDA ,VALID E-TEST $14,000.00
Old 02-01-2008, 09:51 PM
9-Second Club
MADSCI's Avatar
More pics available...
Old 02-02-2008, 01:40 PM
jeff2380's Avatar
Barry,
Shame to see you selling it less than a year after you built it.
How many miles on the new motor?
Good Luck with the sale.
Jeff
Old 02-02-2008, 02:35 PM
9-Second Club
MADSCI's Avatar
Hey Jeff, I put a 1000 miles on the car since I rebuilt it.
With the new job and the band I really don`t have much time to use it, and to me it`s a waste just sitting there, I`d rather see someone else use it for what it was built for!!
Old 02-11-2008, 01:28 PM
9-Second Club
MADSCI's Avatar
May consider trade plus cash.....depending on what it is!
Old 02-11-2008, 08:19 PM
Pomp's Avatar
This car is a beauty!!! The paint job is just increadible and Barry's work is a 10!!!
Old 02-11-2008, 10:15 PM
9-Second Club
MADSCI's Avatar
Thanks Pomp!!
Old 02-12-2008, 02:10 AM
Toronto_LT1's Avatar
Originally Posted by MADSCI
2002 B4C CAMARO 11.90`s @ 113 mph
102000 MILES,420 RWHP,LQ4 364 CUBE IRON BLOCK, HIGH FLOW LID,LS6 INTAKE, PORTED THROTTLE BODY, FULLY PORTED HEADS 2.100 X 1.60 STAINLESS VALVES, PATRIOT GOLD SPRINGS, TITANIUM RETAINERS, COMP CAMS CHROME MOLY PUSH RODS, ROLLMASTER DOUBLE ROLLER TIMING CHAIN, COMP CAMS 232/234 CAM,PORTED LS6 OIL PUMP,ARP HEAD BOLTS, FEL PRO HEAD GASKETS, NEW OIL PAN,MSD WIRES, LONG TUBE HEADDERS, CUSTOM 3" Y PIPE WITH HIGH FLOW CATS, FLOWMASTER CAT BACK, TH 350, BMR TRANS CROSSMEMBER, TCS 3800 CONVERTOR,B&M PRO RATCHET SHIFTER, 3" SEAMLESS CHROME MOLY DRIVE SHAFT, CUSTOM SUBFRAME CONNECTORS, UMI LOWER CONTROL ARMS, UMI RELOCATION BRACKETS, UMI ADJUSTABLE PANHARD, UMI AJUSTABLE TUNNEL MOUNT TORQUE ARM WITH DRIVE SHAFT LOOP, ALUMINUM GIRDLE REAR END COVER, 4.10 GEARS, ARP WHEELS STUDS, QA1 R SERIES ADJUSTABLE FRONT STRUTS WITH 275LB SPRINGS, COMP ENG REAR ADJUSTABLE DRAG SHOCKS, REAR EIBACH SPRINGS, RACETRONIX 225LPH FUEL PUMP WITH HOT WIRE HARNESS, NEW HEADLINER, NEW BRAKES,NEW BATTERY, NEW PAINT, WELD DRAG LITES 15X3 WITH 185/SR 15 TIRES AND 15X10 WITH 275/60/15 ET DRAG RADIALS , FLORIDA CAR NEVER SEEN ANY WINTERS ,VALID E-TEST $17,000.00
wow!nice set up.
trap speed is a bit low though for the kind of power it makes.
Old 02-12-2008, 08:53 AM
jeff2380's Avatar
Originally Posted by Toronto_LT1
wow!nice set up.
Was that at a crappy track? shanonville?
I'd probably let off a little early, if I knew I had to TURN durning the shutdown.
I know that Barry didn't make it to a decent track too many times. The car is NOT dialed in.
Old 02-12-2008, 11:30 PM
9-Second Club
MADSCI's Avatar
The car has been to the track once...It was Shanonville, the track was ****!...lol
as for the MPH being off do the math 3600lbs+ 420 rwhp = 114mph +-
Old 02-15-2008, 08:37 AM
9-Second Club
MADSCI's Avatar
Default More Pics
Here are a few more shots..
Attached Thumbnails 02 Camaro-brandon03-22-07-030.jpg   02 Camaro-brandon03-22-07-035.jpg   02 Camaro-brandon03-22-07-039.jpg
Old 09-29-2008, 03:39 PM
specsbrat's Avatar
Question for you!! If you live in Canada how could this be a Florida car and not have seen any winters???? And I live in Florida so I know what the weather conditions are like and we do occasionally get snow!
Old 09-29-2008, 06:37 PM
umbrae's Avatar
Have you ever been to Ontario? You dont know what snow is buddy! or Salt for that matter!
Old 09-30-2008, 08:40 AM
gauge hp's Avatar
What kind of trades interest you?
Old 09-30-2008, 09:55 AM
Pomp's Avatar
The car in question was imported from Florida and was a Florida State trooper car. I have seen this car before it was painted and it still said state trooper on the back. A B4C is a cop special with lots of heavy duty options.
Old 09-30-2008, 06:46 PM
9-Second Club
MADSCI's Avatar
Thanks Pomp, as for the car it still has the factory paint on the bottom side, no rust....I guess maybe it has seen the odd freak snow storm in Palataka, florida and I`m sure they salt the roads down there like they do here!
Maybe I should have siad this..the car has never seen any winters north of Palataka Florida! As for possable trades talk to me it depends on what it is....
Old 09-30-2008, 06:55 PM
9-Second Club
MADSCI's Avatar
Can you tell the difference????
Which one is Toronto???
Old 09-30-2008, 06:57 PM
9-Second Club
MADSCI's Avatar
Any idea how many of these are in Florida?
Old 10-01-2008, 11:57 AM
spec_j's Avatar
Really. I used to work for FHP and know whats on the cars. SO your telling me that they added all kinds of "special heavy duty options" and im telling you that your so full of crap you dont know what your talking about. Do alittle research before you try and tell someone a lie on the net. There arent any cool badass things they did to the car sorry. It makes me laugh when people come on here and talk about the special options that a car has that their friends buddys uncle had back when he was a special forces officer.
try to start with. You may learn a few things.
Old 10-01-2008, 11:58 AM
spec_j's Avatar
yeah atleast 20 throughout the state, and sure you get bad weather, but you seem to know everything about florida, so i will let you have your moment of glory
Quick Reply: 02 Camaro
