MSD 6010 users. Whats your timing set at? - Page 2 - LS1TECH
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Thread Tools Search this Thread
Old 09-15-2010, 04:43 PM   #21
djquik88's Avatar
Quote:
Now im wondering if 28 degrees at idle is to much?
I think I have mine at 18* at idle. I'm going to bump mine up and maybe clean up the exhaust fumes...they are killing me!
djquik88 is offline   Reply With Quote
Old 09-18-2010, 08:23 AM   #22
tennerv8's Avatar
At my 28 degrees the engine seems to start like **** after its been warmed up.
tennerv8 is offline   Reply With Quote
Old 09-18-2010, 04:15 PM   #23
xpndbl3's Avatar
have timing below 550 rpm at 12 degrees or so, your starter is being overworked with too much timing during cranking when hot and that should fix your problem. Then ramp it back up to 28 degrees at idle like you had it.
xpndbl3 is offline   Reply With Quote
Old 09-19-2010, 05:06 AM   #24
use the vacuum advance feature to add in ignition timing to clean up your idle, have your basic timing at 15-18 deg to let it start easy, then add in say 10deg more using vacuum advance once its running, which makes it nice and clean idling
chris-m is offline   Reply With Quote
Old 09-19-2010, 07:12 AM   #25
forcd ind's Avatar
i start around 30, ramp up for cruise to around 34, but i run boost with a map sensor, so i ramp down to 20 under full boost
one thing i noticed with the Edelbrock intake, the engine wants a good shot of fuel off idle-the engine seemed a little lazy to me, as i open the throttle, i pushed down on the acel. pump at the same time, was much crisper-i switched from the pink cam to the green one, #1 hole, made all the diff in the world
forcd ind is offline   Reply With Quote
Old 09-19-2010, 08:31 AM   #26
tennerv8's Avatar
Quote:
When its warmed up it turns over fast it just takes a while to fire.
Old 09-19-2010, 03:40 PM   #27
In-Zane Moderator
ZONES89RS's Avatar
I need to check mine, but the current setup i have fires up instantly when cold or warm. No prolonged cranking or delay.
ZONES89RS is offline   Reply With Quote
Old 09-19-2010, 06:41 PM   #28
LS_10's Avatar
I have mine at 16-0rpms ramping up to 32-1400 ramping up to 36-3400 ramping up to 39-5000 then straight across from there on to 7000. Fires right up runs great and still on pump gas LS1 decked heads 40thou. going to tune it on the dyno this wed. It is running the same times now on pump gas as it did before with 34coming in at 1600 straight across to 7000 with 110 which i think was to much octane we are going to tune it on 103
LS_10 is offline   Reply With Quote
Old 09-19-2010, 07:28 PM   #29
In-Zane Moderator
ZONES89RS's Avatar
39? Holy hell.
Old 09-20-2010, 06:15 AM   #30
LS_10's Avatar
Quote:
Originally Posted by ZONES89RS View Post
39? Holy hell.
yep when we get it back on the dyno this wed i'm hoping to see if i can go to 40 with the 103 race gas. I know i've not experienced any knock at the settings i have now, Times were improved at the track as well I was running 113 in it to be safe till we got it on a dyno but decided to run 93 in it one night drove it to the track thought what the hell if it blows up then i can get serious right..lol But i was only 2 tenths off what my times were with running 34* with 113 i had ran 6.90 @ 100.1 i played with the timing with the 93 that night at the track and it was hot that night 88 out the times before it was low 60's out. I had ran a 7.10 first pass was like wow played with the timing curve and managed to get a matching 6.90 @ 101.6 out of it on pump gas and a way hotter night
Old 09-20-2010, 12:13 PM   #31
3pedals's Avatar
I might have to experiment with more top end timing???????
3pedals is offline   Reply With Quote
Old 09-20-2010, 02:13 PM   #32
In-Zane Moderator
ZONES89RS's Avatar
Yea, i would like to get the highest timing possible for peak power, but i only have the ability to listen to detonation, dont know if i like that.
Old 09-20-2010, 02:56 PM   #33
3pedals's Avatar
God hates a coward
Old 09-20-2010, 04:37 PM   #34
LS_10's Avatar
I'll let you guys know what i end up at after i get down with it wed on the dyno. I'm hoping to see some decent numbers out of it. Last time we just strapped it down during a dyno day event cause the people wanted to see it and just made a single pull on pump gas and it made 385 to the wheels running really really fat and only 34* that's also through a TH400 big driveshaft ford 9in. with 5.13 gears that really kill hp numbers on a dyno and drag radials. I am going to change the gears to either 4.30's or 4.10's so i can spray it. Things happen way to fast with the 5.13's in it right now for nitrous..lol
Old 09-20-2010, 06:04 PM   #35
In-Zane Moderator
ZONES89RS's Avatar
Quote:
Originally Posted by 3pedals View Post
God hates a coward
I hate destroying engines for no reason.
Old 09-21-2010, 11:17 AM   #36
tennerv8's Avatar
Hey thanks for moving this in here!
Old 09-21-2010, 11:22 AM   #37
In-Zane Moderator
ZONES89RS's Avatar
Trying to get all the carbed base info i can here, fixing to go to be after a 13 Hr shift and just want to get what i can done before work this evening.
-Z
Old 09-21-2010, 03:49 PM   #38
Stock vs mod motor is the difference here anything above 36 degrees is to much for a stock motor my opinion. Someone wanna prove me wrong so i can copy ur curve and make my car faster
96t/acj is offline   Reply With Quote
Old 09-21-2010, 07:39 PM   #39
3pedals's Avatar
mildly joking, but not kidding about experimenting. I beleive low compression engines will allow more timing than higher compression engines. mine has 9.6:1 and I run 36*. I will experiment with more, carefully, watching plugs for signs of deto.
If your motor is 10.5 or better, I dont think more timing will help, but test,test, test, its the only way to know.
Old 09-22-2010, 07:10 AM   #40
In-Zane Moderator
ZONES89RS's Avatar
True man, i need to get some tires that will slip a bit but still hook so i can tune, i dont want to destroy my fresh T56 or snap a DS experimenting.
Related Topics
Thread Thread Starter Forum Replies Last Post
What to do for timing pointer on ATI balancer? midwestjunk Generation III External Engine 8 11-06-2015 05:06 PM
MSD 6012 timing? camarozz383 Carbureted LSX Forum 15 07-20-2015 03:12 AM
qa1 shock settings Adam 2kSS Suspension & Brakes 11 04-02-2009 09:40 PM
PT owners...what is your shift point at? cals400ex Automatic Transmission 3 04-25-2008 02:18 AM
Where to set KYB AGX shocks?? SPECIALIZED STAINLESS Suspension & Brakes 34 02-04-2008 08:02 PM
Tags
32, 60, 6010, 6010ls1timing, aftermarket, ate, cam, carbed, chart, chevy, curve, degrees, ls1, msd, set, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
