MSD 6010 users. Whats your timing set at?
#61
MAP is measured against PSIA, not RPM. Depending on conditions, atmospheric pressure is 14.7 PSIA. Vacuum "pressure" is lower (I.E. 15" vacuum = 7.3 PSIA) and naturally, boost (if applicable) is higher. For instance, a "2 BAR" manifold pressure = 14.7 PSIG = 29.4 PSIA.
Are you counting the start and stop points? I think I have 6 with those in the mix...
#62
I have about 40 at idle and cruse down the highway. with the map as soon as it sees load it knocks it down to 29.
Big thing with running more timing is it will drive nicer and MPG should go up some. Just need to make sure when it sees load you kill some so you don't rattle it.
I have 40 in it as high was 3000 with no load.
Tim
Tim
#66
Here's what I have right now...probably going to actually back off 1-2* across the curve...
Idle-2000 - 20*
2000-3000 - 24*
3000-4000 - 26*
4000-5000 - 27*
5000-5500 - 28*
5500-6000 - 29*
Specs:
383 LS1
238/244 Hyd. Roller
MTI Stg 3 241 Cast Heads
Edelbrock Performer Dual Plane Intake
850 Carb
11.5:1 Compression (I think, could be a little higher)
In a jet boat...
BTW - that timing curve is what my motor liked the best when it was dyno tuned while still injected and in a car (although it preferred 27-28* in the upper rpm, but I forgot until I posted this).
Idle-2000 - 20*
2000-3000 - 24*
3000-4000 - 26*
4000-5000 - 27*
5000-5500 - 28*
5500-6000 - 29*
Specs:
383 LS1
238/244 Hyd. Roller
850 Carb
In a jet boat...
#71
Great info!!! i got my 6.0 with 317 heads milled .050, edelbrock 2216 cam, 750 dp carb, th400 with 3000 stall, 3.73 gears in my 1987 c-10 pick up truck, i was using the 6 pill and went 13.58 in the quarter mile, then i took off the pill and did 15* at 0 , 33* at 3000 and 37* al the way until 6700, and my truck went 13.32, tomorrow i will go again to the track and try more of this and see if i can get better results.
#73
What kind of fuel are you running?
#76
#79
thanks for the thread here.. was having a run on issue with a new l92 carb engine with a bunch of cam.. i am running 20 at idle and ramping up to 31 to be conservative.. but it fixed all. .i am able to run the idle lower .. the AED carb really digs it and all problems solved except the law enforcement ones surely to come.. thank you
