My carbed ls3 stroker - LS1TECH
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Thread Tools Search this Thread
Old 11-05-2010, 11:08 PM   #1
Default My carbed ls3 stroker
Hey guys, not a big poster on lstech, but I thought you car guys might like to take a look at my new LS motor I had built for my airboat.
4340 forged 4'' crank, ACL/Kings main bearings ARP PRO main studs
6.2 block, 4340 4'' stroke crank, 4340 H beam 6.125 full floating bushed rod's, custom forged pistons, total seal file fit rings, ARP pro Main Studs, ACL bearings
LS3 block with a 4340 forged 4'' stroke crank, with 4340 full floating bushed H beam rod's with ARP rod bolts, Forged flat top pistons with Total Seal file fit rings, ARP Pro Main Studs this combo come to 418 cubic inches. Demon 850 cfm carb with annular boosters sitting pretty on top of a spider intake. We're making over 600hp with this combo! It spins a 4 blade R series carbon fiber prop(13''x82'') up to 5600rpms with 12 degrees of pitch in it. All that goes through a 2.68 to 1 gearbox
LS3airboat is offline   Reply With Quote
Old 11-06-2010, 12:02 AM   #2
oh yeah, I almost forgot. We built this to be a pump gas motor and so far it is just that! Ran great on the thrust tester with 93 octane.
Old 11-08-2010, 12:48 PM   #3
1 FMF's Avatar
what are you running for ignition?
1 FMF is offline   Reply With Quote
Old 11-08-2010, 09:27 PM   #4
In-Zane Moderator
ZONES89RS's Avatar
That is a sick *** motor man, i am going to move this to the new carbed section, this is(was) the old SBC section.
ZONES89RS is offline   Reply With Quote
Old 11-09-2010, 09:20 AM   #5
That's awesome. You air boat guys are crazier than car guys. LOL.
Oldsmobility85 is offline   Reply With Quote
Old 11-09-2010, 09:32 AM   #6
Quote:
stand alone programmable ignition controller, gm coils.
Old 11-10-2010, 07:22 PM   #7
RENE'S RAGE's Avatar
Way to fast on water for me.
What brand pistons and are they 4.080.
RENE'S RAGE is offline   Reply With Quote
Old 12-10-2010, 06:09 PM   #8
Old 12-11-2010, 12:14 AM   #9
dmracing's Avatar
How fast does something like this go?
dmracing is offline   Reply With Quote
Old 12-11-2010, 09:16 AM   #10
Pop N Wood's Avatar
That thing is pretty.
Hard to believe you will keep it right side up with all that motor.
Pop N Wood is offline   Reply With Quote
Old 12-11-2010, 09:37 AM   #11
396D1SS's Avatar
crazy
396D1SS is offline   Reply With Quote
Old 12-11-2010, 10:16 AM   #12
A few questions. What heads are you using and what are the cam specs? How much timing do you run for pump 93 octane? What comp is it. My power requirements are simular to yours but it is a jet boat.
allblowdup is offline   Reply With Quote
Old 12-12-2010, 02:40 PM   #13
Quote:
The motor was built in florida by a company called Waterthunder proformance, they specalize in LS motors for airboat use. Though they have built engines for drag cars, jet, boats, drag airboats, and airboats. I'm currently in Iraq and I've yet to lay my eyes on the motor and I wasn't involed to much in the build up of it. Dave has done tones of R&D on his custom cam grinds from carbed and EFI engine and I don't think he'll be giving out the specs. The heads are L92.
You can check out his website www.waterthunder.com or even give him a call, but he's an engine builder and all the R&D he has done puts food on his table, I doubt he'll give any info up at all unless your considering buying a motor from him.
you can also see more pictures of the engine/boat build on my site, www.bullshithill.org
Old 12-12-2010, 02:46 PM   #14
Quote:
My boat is pretty big(8'x16') and it really isn't built for speed. If I took this motor and put it on a small hull I could make it scream. I haven't got it on the water yet but it will be around 40-50mph. The boat will also pretty much go anywhere on dry land and up hills.
The drag racing airboats run a 400' track and top out around 98 mph in the unlimited class in 400'. They'll goes faster, but the get pretty squirrly and it takes some ***** to stay in the gas to get up to higher speeds.
Old 12-12-2010, 03:04 PM   #15
LS_10's Avatar
Hot Damn that's sexy!
LS_10 is offline   Reply With Quote
Old 12-13-2010, 04:44 PM   #16
I just noticed that they was core plugs in the heads so they may be catherderal ports. Not bad or good just an observation. Awsome looking engine.
I assume that you are over ther in the service so even though I am from Canada I would like to say thanks for your service!!
Old 12-13-2010, 04:46 PM   #17
dmracing's Avatar
He says in post 13, that they are L92 heads
Old 12-21-2010, 06:02 AM   #18
If he's in the service hes been saving his money since he got there that thing looks expensive. I would guess contractor. Blackwater or similar?
Old 01-28-2011, 08:19 AM   #19
Here you go guys, I've got her all finished up and put about 30 hours on her while I was home. She runs like a bat outta hell.
Old 01-28-2011, 11:55 AM   #20
NICE! Could you get us a sound clip or a video?
team39763 is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
2002 Camaro SS Polished & Coated The Guz Appearance & Detailing 14 09-13-2015 11:44 PM
FS: SBC 406 longblock, 4340, solid roller, Brodix, pumpgas Chevy406 Parts Classifieds 2 01-22-2010 05:25 PM
Tags
1000hp, 4, 416, airboat, annular, carbed, carbuerated, combo, crank, engine, ls3, reviews, seal, stroker, total, waterthunder
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
