Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
71 Chevelle 5.3 Carb'd Build cam recommend
Old 01-05-2011, 09:57 AM
Pro-Tour Heavy Chevy's Avatar
Default 71 Chevelle 5.3 Carb'd Build cam recommend
Okay before the FI guys jump me here's how this has all come together for me.
A 2004 5.3 with 48k on it literally fell into my lap. The manifold was cracked from the pull out and it came with no Electronics except for the Coil pack harness. The motor also came with the Alt/PS bracket with the pump. The internals are in excellent condition. Then a Edelbrock RPM manifold w-controller was handed to me by a family member with deep pockets who decided to go LS3. and for a pan I have a Milodon pan kit that I got too. This is what I have to work with. Since my Trans is a 200-4R and have the Carb-TV cable/Linkage and already sorted out so I can just Transplant that onto the manifold. As for the Motor I'm looking at swaping the cam,valve springs and Pushrods. I going for Broad power thru the low and Mid range not Peak Numbers.I've been looking at the Edelbrock 2215 and 2216 cams as well as the GM Hot Cam and the Comp Cams 273 grind. This will be street driven with limited track time so looking for good street manners and good torque. I've heard mixed results with the LS-6 cams with carbs, but I can get one of those on the cheap. Still need to get a few things like headers before the swap starts and I put the car in garage purgatory.
Old 01-05-2011, 01:25 PM
In-Zane Moderator
ZONES89RS's Avatar
Depends, do you have a stall, are you getting one? What size if so? Otherwise, no stall, dont, but a cam in it besides stock cams like the LS6. If you will get a 2600-2800, a Hot cam would probably fit the bill for you, the max i would go in the cam department if you did go with a 26-2800 stall(those are like 200$ BTW), a 220/224 duration grind will have some decent low end, but the mid range would be awesome, no matter what you do with the LS engine, any real cam wil end up carrying over to 6500 RPM or so before falling off.
Old 01-05-2011, 02:29 PM
Old School Heavy
speedtigger's Avatar
The Comp 273 grind that you listed would probably be a good choice.
Old 01-05-2011, 03:45 PM
hifi875's Avatar
give pat g or geoff at eps a shot. they can spec u a custom cam to your needs alot better than a off the shelf cam. its only $25 more for a custom grind. They specd me 218/222 for my carb'd 5.3 in my 69 camaro.
Old 01-05-2011, 05:33 PM
I'm currently running a 2600 stall FWIW
Old 01-05-2011, 05:58 PM
In-Zane Moderator
ZONES89RS's Avatar
Do you know what it will foot brake to with whatever engine might have been in front of it before or is it never used?
Old 01-05-2011, 11:12 PM
00byrd's Avatar
Geoff at eps just got me a cam also for my 5.3 gonna be nice. Super good guy to deal with give him a call he cam set u up with a cam kit.
It's Currently being used behind a Mild 350. Running 3.73 gears in a 12 bolt with a true-trac diff.
Old 01-06-2011, 04:50 PM
In-Zane Moderator
ZONES89RS's Avatar
Ok cool, something in the mid 220s would work well with that stall speed, should be a quick idle and wrap pretty fast and have lots of mid range.
Old 02-09-2015, 10:28 PM
henryleec's Avatar
Default 83 cutlass 5.3 carb'd cam recommendation
I want to know a good choppy cam that I can run with just changing my spring in my heads. I am gone be running a mild 350 turbo with a 2700 to 3000 stall
Quick Reply: 71 Chevelle 5.3 Carb'd Build cam recommend
