Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
HP guestimates of new combo
Old 03-01-2011, 12:32 PM
Kwikcad500's Avatar
Smile HP guestimates of new combo
Im building a new motor for the season and wanted to see what the LS pros think.
NEW COMBO:
365ci (.005over) iron block
LS3 heads
12.5 to 1 compression
K1 rods
Victor JR single plane
Full length headers 1 3/4-1 7/8 stepped headers
cam specs in progress
Holley 1000HP carb
MSD-6010 ignition
Old 03-01-2011, 01:33 PM
In-Zane Moderator
ZONES89RS's Avatar
Not sure without cam specs, but that combination should produce 475 give or take on a dyno to the back tires, depends on the dyno and the rest of the drive line.
Old 03-01-2011, 01:41 PM
Z284thgen's Avatar
what tranny
Old 03-01-2011, 02:19 PM
hornerhotrods's Avatar
If that motor @ 12:1 carbed with any respectable camshaft put down only 475 id set it on fire and roll it off a cliff.
Old 03-01-2011, 02:52 PM
In-Zane Moderator
ZONES89RS's Avatar
Assuming he is using a automatic with a large converter, the dyno readings are not what you would think, you cannot go by dyno numbers asides from tuning purposes.
The track is where you can find the power output. A friend with a LS3 with cam and the works made 460 through a stalled auto, and every dyno will read different, so hence the reason i say "give or take".
Old 03-01-2011, 02:53 PM
Kwikcad500's Avatar
Trans is a T400 but may be switching to a T350 this year, I was hoping for 500 to the wheels on a dynojet. The last combo was a junkyard LQ4 with untouched 243's, mild cam, headers with a Wegner single plane and made 400hp to the wheels with a badly slipping converter, T400 and 4.10 gears with Hoosier Quick Time Pro's D.O.T(slicks with grooves) on a Dyno Jet. I replace the converter with a 4000stall unit and the car picked up half a second in the 1/4 along with 1.56 60ft. Anyway back to my new combo...I Havent milled the heads yet but i am thinking about it. Ive got a custom cam coming from on of the sponsors(not sure if its ok to say who it is though). I do not have cam specs as of yet but it will be taylored to the combo.
Old 03-01-2011, 03:00 PM
Kwikcad500's Avatar
I use the chassis dyno for tuning purposes and finalize my tune at the track for different weather conditions. Ran a best of 11.53 last year with the junkyard combo in a 4000lb car and was very surprized it ran like it did. Probably going to an electric w/p this year to freeup some extra HP too.
Old 03-01-2011, 04:43 PM
NoMoreFWD's Avatar
Pump or race gas?
Old 03-01-2011, 05:03 PM
11 Second Truck Club
bluecajun5.3's Avatar
i would say 500 to the tire would be a good guess also.
Old 03-01-2011, 05:49 PM
Old School Heavy
speedtigger's Avatar
I don't know about RWHP, but I would say near 600HP at the crank with the appropriate cam.
Old 03-01-2011, 07:35 PM
SteelCityMaro's Avatar
475-500 you should do some port work on that victor jr to flow a bit more
Old 03-02-2011, 07:46 AM
Kwikcad500's Avatar
The 10" 4000 stall converter will probably not be able to be used. Im waiting on cam specs for that but it will probably be 5000+ and the combo will be on race gas for a while then E-85 or Methanol. Im gonna have the Jr flowed on a bench.
Old 03-02-2011, 02:48 PM
In-Zane Moderator
ZONES89RS's Avatar
Yea, i wouldnt expect the numbers ona dyno to look as pretty as they could be with a manual trans, so anywhere from 450 to 500 is possible, depends on the dyno ect.
Old 03-04-2011, 07:46 AM
agreed^^^^^^
Old 03-04-2011, 03:50 PM
Kwikcad500's Avatar
620ish is the goal, 600 is close enough for me. Cam will be in the mid 230's I /240's E
Old 03-31-2011, 09:33 AM
Kwikcad500's Avatar
Decided to go more agressive on the cam selection. Compression will be bumped to 12.5 from 12 to 1. Its going to be around 250* @ .050 on a 110 or 112 LSA. Leaning towards the 112, I had great results with my Catherdal port LQ4 pump gas motor last season using a 112 LSA in my heavy Coupe Deville. I think average across the board HP and TQ numbers are more important in my combo than peak numbers. I need to get from point A to point B as quick as possibe.
Old 03-31-2011, 09:36 AM
Old School Heavy
That is one serious camshaft.
Old 03-31-2011, 09:55 AM
Kwikcad500's Avatar
I have yet to pull the trigger on the cam but i plan to spin it to 7500, the heads have enough air to go 8000+ but i dont want to spin it that high, ide like the motor to live for a while. I'll be using race gas but i plan on experimenting with E85/98. Ive been talking to a couple different cam guys but undecided at the moment. Its still a cast crank and im sticking with the stock rockers. The converter will be a 4700-5000 8". Will more than likely be an 8* split. Any input is welcome......
Old 03-31-2011, 09:56 AM
Old School Heavy
Originally Posted by Kwikcad500
I have yet to pull the trigger on the cam but i plan to spin it to 7500, the heads have enough air to go 8000+ but i dont want to spin it than high, ide like the motor to live for a while. Ive been talking to a couple different cam guys but undecided at the moment. Its still a cast crank and im sticking with the stock rockers. The converter will be a 4700-5000 8". Will more than likely be an 8* split. Any input is welcome......
Sounds like a rocket ship in the making. I know you are going to post a video when it is done so we can hear that sweet LS music!
Old 03-31-2011, 12:09 PM
Kwikcad500's Avatar
Oh yes I will def post pics and video's!
Quick Reply: HP guestimates of new combo
