old school tuning (no wideband) - LS1TECH
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Thread Tools Search this Thread
Old 05-25-2011, 11:19 AM   #1
Default old school tuning (no wideband)
I cant run an O2 sensor on my boat due to running wet exhaust.
Here's what my setup is doing
Think of the setup as a car with a ton of stall and a single speed tranny.
  • Tip in from idle is fine.
  • Punch from idle it will bog or die.
  • It idles fine (approx 8-900 RPM's) and fires up with one push of the gas peddle before cranking.
  • Running WOT isn't possible. MAX is 5300 rpm's and it will bog with peddle left.
  • What I am thinking is the WOT bog is a lean condition.
  • I haven't messed with the carb at all except for float adjustment.
  • 5.3L stock with a 750 DP holley. #2 pill. (map disconnected)
  • fuel pressure is 7lbs
  • I can reach the intake behind me while running WOT and have thought about giving it a little spray of carb cleaner or something to see if its rich. Any comments on this??
I am planning to mess with the timing and jetting this weekend so any help would be appreciated as the boat is 250 miles away from home and I can only tune it on the weekends.
sandeggo is offline   Reply With Quote
Old 05-25-2011, 11:34 AM   #2
Ravenous T\A's Avatar
I am doing what alot of people who have that Bog are doing by upgrading to a 50cc accelerator pump. There are some guys who have rejetted, switch bleeds and etc...but this seems like a quicker fix
Ravenous T\A is offline   Reply With Quote
Old 05-25-2011, 11:37 AM   #3
Here is a thread that may help u too
http://www.ls1tech.com/forums/carbur...b-stumble.html
Old 05-25-2011, 11:42 AM   #4
Yeah I have read that thread and plan on doing the conversion. My issue with my setup is the top end
Old 05-25-2011, 11:51 AM   #5
Moderator
jimmyblue's Avatar
"Wet exhaust", how wet? Back in the day I welded O2
bungs into the manifolds and used narrowband sensors
for idle screw / cruise jet selection. Is there a dry spot?
Is the fuel pump up to the load at WOT? Is pressure
hanging tough?
jimmyblue is offline   Reply With Quote
Old 05-25-2011, 12:07 PM   #6
hanging tough?
its water injected right near the head ports. Its done to cool the exhaust. The fuel pump is staying right around 6-6.5 WOT. The total fuel travel from the tanks to the pump to the motor is only 3 feet of hose.
Old 05-25-2011, 03:31 PM   #7
Pop N Wood's Avatar
Man, if it is that far off try two jet sizes larger and see what difference it makes.
I would get the jetting right at cruise then worry about accelerator pumps later.
I know you can use propane to check for vac leaks at idle, and even to check the idle mixture. Not sure if it works at WOT.
By the way, I assume this is the first time you have run the motor and that it didn't run right then suddenly go bad?
Also don't forget the basics, like good ignition, no leaky carb gaskets, blown power valve, fouled plugs.
Pop N Wood is offline   Reply With Quote
Old 05-25-2011, 04:34 PM   #8
Correct I have ran it twice and its acting like it always has. It runs perfect in the mid range and has gobs of power. I have the assorted jet kit so I will try fattening it up a bit. I bought the 50cc kit today so I can try that as well. The carb is brand new with no leaks and I sure hope the power valve is working.
Old 05-27-2011, 03:03 PM   #9
tennerv8's Avatar
Okay everybody hold on a second. If he's using the ignition pills, they have a 5500 rpm rev limiter built into them. It sounds like his rpm issue is that, not the carb. Pull the pill out and tune it on your laptop.
tennerv8 is offline   Reply With Quote
Old 05-27-2011, 09:27 PM   #10
Old School Heavy
speedtigger's Avatar
Quote:
Wow. I guess we missed the obvious.
speedtigger is offline   Reply With Quote
Old 05-28-2011, 09:56 AM   #11
It wasn't hitting the rev limiter. I have hit the rev limit a couple times when I catch air.
I did a basic timing curve, fattened up the secondaries to 82's, and put the 50cc on. It's running better but I gotta throw a little more timing to it. The top end bog is almost completely gone and the off idle stumble is almost 100% gone. I didn't change the squirter yet and I'm running the brown pump cam.
0-800 rpm 20*
800-4500 31*
4500-5500 29*
5500 on up 31*
I'm also now hitting 78.1 mph on gps.
Before I hit 72.4
Old 05-28-2011, 03:18 PM   #12
3pedals's Avatar
have you adjusted all the free-play out of the accelerator pump linkage?
there are 2 positions the pump cam can be set at as well, set it to provide the most pump linkage movement at beginning of throttle movement - to get the greatest shot of fuel at tip in. this will improve the off idle stumble.
for the top end bog, I would make a hard run in the range that boggs, and quickly shut the engine down and check the plugs. if they have any white on them it is LEAN, if they are wet and/or black, its rich. I would guess its lean, as the engine will bog if its too lean, but it will start to missfire and sputter if its too rich.
Barrett
3pedals is offline   Reply With Quote
Old 05-29-2011, 02:23 AM   #13
I think thats only partially true. You can change the rev limit with the interface and still use the curve 'pills'. I am doing it. For now.
gjestico is offline   Reply With Quote
Old 05-29-2011, 05:42 PM   #14
tennerv8's Avatar
Quote:
Yes but the second you plug the pill in it erases any saved programing. Doesnt it? I may be wrong.
Old 05-29-2011, 07:45 PM   #15
S10xGN's Avatar
I don't know that it "erases" it, but it definitely overrides any user programming.
S10xGN is offline   Reply With Quote
Old 05-30-2011, 08:16 AM   #16
tennerv8's Avatar
Quote:
Yes thats what i meant.
Old 06-04-2011, 10:46 AM   #17
ok so now I'm a little more confused. I jetted up the secondaries and made my own timing curve. well now the motor will only spin 5100 but the boat goes faster.
Is my above timing curve too conservative?
Old 06-04-2011, 02:22 PM   #18
3pedals's Avatar
how is this engine built, what cam, compression etc? maybe it just doesnt have enough power to go any faster than 78mph on water. I assume it direct connected to the drive?, or does it have some kind of fluid coupling between the engine and drive? I dont understand how the boat can go faster with less rpms?
Old 06-04-2011, 02:32 PM   #19
It's a bone stock 5.3. It can go faster with less rpms if the power is more efficient. The rpms and top end speed are not directly connected. The motor is connected with a spicer driveline, like a little driveshaft. For example my old motor turned 6300 rpms but only went 64.
Old 06-04-2011, 02:45 PM   #20
3pedals's Avatar
I would try changing your timing curve from 800 - top rpm up to 33* strait, and see how it responds, I wouldnt bother with a timing dip at torque peak. what do your plugs look like after a full load run? if you can post a picture of what you find, it might help.
you need to kill the engine immediately after top speed of the run to avoid coloring the plugs with anything other than WFO throttle.
EDIT: I just checked out your build thread, NICE setup, I like!!
Tags
53, boat, budget, carbed, cooled, curve, exhaust, ignition, ls1tech, timing, tuning, ve, water, wideband, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
