Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
bbc water pump on ls
Old 01-10-2017, 03:19 PM
In-Zane Moderator
ZONES89RS's Avatar
I've made like 18-20 passes back to back before. Didn't skip a beat. Lol. Don't know anyone who can say they have done as many in a couple hours.
Old 01-10-2017, 10:52 PM
HioSSilver's Avatar
Originally Posted by ZONES89RS
I have not found a reason to run an electric pump yet. Much less a BBC pump. The truck pumps are 76$.
Although i have no reason to run a bbc pump either part of the reason i like a ewp is because i can do away with the tensioner. The belt then only runs around the crank/alt/ps if you have that. It reduces clutter/weight and some rotating weight.
I have with muh ewp
Old 03-25-2017, 08:09 AM
tom70's Avatar
ezstriper do you have part list of how you did that I want to do same thing for drag race only engine thank you
Old 03-28-2017, 12:35 PM
cbunn's Avatar
I'm in the middle of gathering parts for a LS swap in a 89 Fox.I'm gonna run the BBC water pump from ebay and ICT adapters.The water pump is E-5927-P and the ICT adapters are 551515 and then you'll need a Y and other fittings.I've not done this but a friend through facebook has and was nice enough to share.I hope this helps,
Old 10-23-2017, 04:49 PM
187racing's Avatar
Originally Posted by ezstriper
also here is a shot of setup did on my sons foxbody swap
Love that hose setup ezstriper where did you come up with the fittings? I know this tread is old but thats just what im looking for!
Old 10-23-2017, 06:39 PM
Doug G's Avatar
After installing an EWP, I was pointed in the direction of DaviesCraig for a fan controller...I could have used their set-up and maybe save a few $$ ?
https://www.summitracing.com/parts/d...8650/overview/
https://www.summitracing.com/parts/d...8160/overview/
Old 11-02-2017, 04:05 PM
tom70's Avatar
I got all fittings from e-bay. bought adapter plates from jeg's
Old 11-03-2017, 05:35 AM
dealrcn's Avatar
I run a bbc electric pump with the ICT billet adapters on our 6.0 S10 build. I made a top hose adapter/splitter from stainless to split the top hose into 2 hoses to the pump. It has worked flawlessly for 2 years at the track.
Old 11-03-2017, 07:39 AM
AnotherWs6's Avatar
That's definitely cool looking, but there is a lot going on right in front of the motor, might cause issues with accessories, no?
Old 11-03-2017, 11:22 AM
8.Lug's Avatar
What accessories? Drag car. Maybe need a tiny alternator but that's about it.
Old 11-04-2017, 05:21 AM
Doug G's Avatar
I only have an alternator...but relocating due to Meziere EWP.
I guess IF you had AC, PS, ETC....yes, could be an issue ?
Old 11-29-2017, 04:55 PM
  #32
Hellsx's Avatar
Would you have a pic or two to show how you did it? Im right into this project wise and already have CSR BB pump id like to use on my set up.
Gathering info and inspiration to make up my mind on how to best go about it!
Thanks a lot,
Lead.
Old 12-09-2017, 11:45 AM
  #33
jerr6's Avatar
I'm joining the EWP crowd. Do most of you guys put the pump relay on a switch or on all time ignition on ? I could see a switch would be convienant but easy to forget to turn on. I went with a meziere pump. Seems to be the cheapest route since I'm only running a alternator.
Old 12-09-2017, 04:37 PM
  #34
Doug G's Avatar
Mine is on a relay and comes on with engine start.
My fans are on their own relays and cycle on/off as needed.
I thought about a bypass for the pump for cool downs, but as of right now, not needed.
Old 12-10-2017, 11:42 AM
  #35
HioSSilver's Avatar
You could mount the pump anywhere. Just run the hoses to it.
Old 12-10-2017, 08:37 PM
  #36
jerr6's Avatar
Thanks, I think I'm also gonna wire it for ign on- pump on also. Easy enough to add a switch later if I need it.
Old 01-16-2018, 09:29 AM
  #37
79mustangswap's Avatar
What adapter plates and water pump did you use?
Old 01-16-2018, 10:29 AM
  #38
Fuhnortoner's Avatar
I paid 140 for my LS water pump at Autozone and it has a lifetime warranty. Just sayin...
Old 01-16-2018, 10:38 AM
  #39
Hellsx's Avatar
What did you use for the "T" fitting? Hard to see.... All looks good in there!
Old 01-16-2018, 12:29 PM
  #40
cbunn's Avatar
Thanks for the info and any input from everyone so far.Been at a stand still but hope to get to going at it soon.More important stuff keeps coming up,but I did get the rings filed for one side lol.
Quick Reply: bbc water pump on ls
