Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Victor jr or super victor ?
Old 01-18-2012, 08:58 PM
AINT SKEERED's Avatar
Default Victor jr or super victor ?
At what performance level does the super Vic do better then the Vic jr?
Old 01-18-2012, 09:13 PM
xpndbl3's Avatar
what heads, cubes, cam, rpm range, etc?
super vic here with 1" HVH spacer
Old 01-18-2012, 10:14 PM
5.3 heads milled to 54 cc , eps custom grind 238/250 .603/.596 110 ls,106 cl 347 ci , 2800 lb or less race weight s10,4.11- 4.56 gears in ford 9" rear, 2" tube headers , th 350 Trans and 8" 5000+ stall.
Old 01-18-2012, 10:15 PM
And shifting around 7200-7400 rpms
Old 01-18-2012, 10:37 PM
Prorac1's Avatar
I would say super victor without a doubt. Eric L
Old 01-18-2012, 10:56 PM
xpndbl3's Avatar
i'd have a super vic on there as well for that combo, and try out a HVH spacer as well at the track, it picked up for me, might do the same for you if you can clear it under your hood. It is a tall combo.
Old 01-19-2012, 09:52 AM
Should clear. Thanks guys
Old 01-19-2012, 10:18 PM
MikeFSKSpeed's Avatar
I think you have enough room!
Old 01-20-2012, 08:24 PM
Roller406Bu's Avatar
what size spacer did you go with??
Old 01-20-2012, 10:46 PM
xpndbl3's Avatar
both the 1" and the 2" HVH super sucker picked up mph, right now I'm running an air filter on the car while cruising it so I have the 1" on there. Sold the 2" to mw66nova who also picked up mph with the 2" from nothing at all.
Old 01-21-2012, 10:43 PM
I have a 1" wood spacer I will try out. I also will be running a filter, probably a 5-6" tall filter. What ever fits
Old 01-22-2012, 07:12 AM
toxic99's Avatar
Think you have enough hood to fit a toilet so...
Old 01-22-2012, 10:16 AM
xpndbl3's Avatar
doubt a wood spacer would do a thing compared to the HVH spacer.
Old 01-22-2012, 10:55 AM
Old School Heavy
speedtigger's Avatar
I know guys who picked up with a 1" open spacer. Some have said a tenth.
Old 01-22-2012, 02:02 PM
An HVH may be better but I will still be trying what I have. I may even use the 1" I have and a 1" HVH , never know until you test it.
Old 01-22-2012, 03:09 PM
westTEX26's Avatar
The wood spacer will help a tiny bit , the hvh is the best carb space around.
Old 01-22-2012, 03:56 PM
xpndbl3's Avatar
step it up
2" and super victor from 2010 season
1" and nitrous plate from 2011 season
Old 01-23-2012, 02:21 PM
In-Zane Moderator
ZONES89RS's Avatar
I gained .2 with my 2 inch on my 6.0 and Vic jr, it is a 4 hole I ported to mock a hvh.
Old 01-23-2012, 07:49 PM
this it?
http://www.highvelocityheads.com/ss.htm
Old 01-23-2012, 08:03 PM
I sell the HVHs. A two 2" on my Gen 1 SBC picked up 18hp on the dyno! Needed some tweaks to airbleeds but it was worth it!
Quick Reply: Victor jr or super victor ?
