Thoughts on 111 LSA on carb APP. - LS1TECH
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Thread Tools Search this Thread
Old 02-04-2012, 09:51 AM   #1
BTLFEDSS's Avatar
Default Thoughts on 111 LSA on carb APP.
Just as the title says just wondering what you guy's thoughts are on a 111 LSA?? I realize a 110-108 is probably better but just curious of your thought on runnning 111 with a carb???
BTLFEDSS is offline   Reply With Quote
Old 02-04-2012, 10:04 AM   #2
richard david's Avatar
My first cam was 112 with Carb and it worked fine. Change to a 109 and pick up 3tents
richard david is offline   Reply With Quote
Old 02-04-2012, 10:40 AM   #3
the custom carb cam I was spec'd is @ 111+4 but LSA is just one part of the equation.
B
bitterman is offline   Reply With Quote
Old 02-04-2012, 10:48 AM   #4
In-Zane Moderator
ZONES89RS's Avatar
111 is better than 112+ in most carbed applications. That simple.
ZONES89RS is offline   Reply With Quote
Old 02-04-2012, 10:52 AM   #5
Prorac1's Avatar
Some of the carb specific cams go down as low as 106 installed. But, depending on the piston and heads, becareful how tight you go, as flycutting may be required. It all depends on what you want and what your willing to put up with. The carb database sticky at the top of the carb forum page is an INVALUABLE source of information on this subject. Best of luck with what ever cam you choose. Eric L
Prorac1 is offline   Reply With Quote
Old 02-04-2012, 06:56 PM   #6
Fbodyjunkie06's Avatar
Quote:
This should be your tell all right here bottlefed. Carbs and single planes like tight lsa's.
If you were going to spray it I would say the 111 would be ideal, but if it's going to be strictly N/A go tighter around 108-109.
Fbodyjunkie06 is offline   Reply With Quote
Old 02-04-2012, 07:21 PM   #7
Old School Heavy
speedtigger's Avatar
Narrowing the LSA increases overlap. On cars with good and proper headers and free flowing exhaust, the scavenging effect of the headers increases the intake pulse in the midrange. This boosts the midrange power. The increase/advantage is exaggerated on cars with large volume heads and/or short runner single plane intake manifolds. This is why you see narrow lobe center cams being recommended and run on drag cars with single plane intakes. Cars with automatic transmissions tend to prefer a narrower lobe center than a stick shift car.
The above information is not specific to LS motors. We have know this for decades. However, the LS motors appear to be no exception.
speedtigger is online now   Reply With Quote
Old 02-05-2012, 03:20 PM   #8
In-Zane Moderator
ZONES89RS's Avatar
I have seen allot of tighter lsa motors get hit with notrous and do just fine, the ones that did not do so well happened to be simply blowingthrough the converter, lol.
Old 02-06-2012, 12:59 AM   #9
good info
pairof69s is offline   Reply With Quote
Old 02-06-2012, 07:46 AM   #10
The stunningman's Avatar
Quote:
They did fine but they were feeling 100hp hit on 150 jetting because of the valve timing.
The stunningman is offline   Reply With Quote
Old 02-06-2012, 08:52 AM   #11
1badeagle's Avatar
My carbed cam for a 200 hit from Patrick G is a 110+4.
1badeagle is offline   Reply With Quote
Old 02-06-2012, 05:45 PM   #12
In-Zane Moderator
ZONES89RS's Avatar
Quote:
Any proof to back that? I can believe it at lower revs, but at higher RPM, where the events happen at a increased rate, it may very well not be so. If a tighter LSA brings TQ in faster on motor, it may bleed off some power from nitrous, but on the bid end, i find it not so easy to believe it is not getting the most from it.
I have several build forged nitrous motors with the old SBCs and are on a 106, they run pretty damn hard, gaining allot from small 200 shots.
Old 02-07-2012, 01:15 PM   #13
that being said.... am I screwing up by running am efi cam in a carb app? The motor happened to come with a 224/228 581 588 on a 114.
Mako77 is offline   Reply With Quote
Old 02-07-2012, 02:12 PM   #14
Old School Heavy
Quote:
You should start your own thread on the topic and list all of your set up. Then people can comment without hijacking.
Old 02-07-2012, 05:28 PM   #15
k sorry. thought it might be relevant.
Old 02-07-2012, 06:17 PM   #16
Old School Heavy
No worries man. Just a way you can get everyone's thoughts for your particular application.
Old 02-08-2012, 08:12 AM   #17
Anytime you run a tight LSA both the intake and the exhaust valves are opening closer together leaving "both doors open". This allows more of the nitrous charge to slip out the open exhaust valve. Taking power away anywhere in the powerband will affect the whole run. Obviously as you know the narrow LSA actually narrows the powerband, so the whole shot will actually be optimized for a very short distance of the pull. I don't have actual numbers but I have have read up on test done. None of my links are saved but I will try and find one for you when I get a chance.
Related Topics
Thread Thread Starter Forum Replies Last Post
Wtb ms3/ms4 on a 111 lsa davidz28man Parts Wanted 1 04-10-2014 05:11 PM
lq4 with ls3/l92 heads ptv clearance sic7camaro Carbureted LSX Forum 9 03-13-2012 09:34 PM
Quick LSA question JustAnotherLS2 Generation IV Internal Engine 5 11-08-2010 09:16 AM
Carbed cam opinions ramdaspadhye Conversions & Hybrids 17 10-09-2009 12:27 PM
what heads to match with TR 230/224 lsa 111 neil1b Generation IV Internal Engine 10 10-13-2008 10:52 AM
Tags
110, 1114, 112, app, cam, camshafts, car, carb, carbureted, carburetor, center, engine, lobe, ls1tech, lsa, search, setup, tight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
