Anyone using the Edelbrock MSD module? - LS1TECH
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Thread Tools Search this Thread
Old 04-01-2012, 11:27 AM   #1
GNCLONE's Avatar
Default Anyone using the Edelbrock MSD module?
Is anyone using the non-programmable box that comes with the 7118 kit?
I've used different "pills" in it and can't tell any difference. I thought someone on here once said it runs fine with no pill at all.
GNCLONE is offline   Reply With Quote
Old 04-01-2012, 02:26 PM   #2
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
When you pull a pill out it remains on that timing pill. So say you have Curve 6 in and pull it out, the box will remain on that curve until a different one is inserted
Curve 3 is default on the box
Z28/2002 is offline   Reply With Quote
Old 04-01-2012, 05:16 PM   #3
GNCLONE's Avatar
Have you noticed much difference between the pills?
Old 04-01-2012, 10:10 PM   #4
Z28/2002's Avatar
I never noticed a difference and I ran the Edelbrock box for almost a year then switched to the MSD 6010
Old 04-02-2012, 05:11 AM   #5
I have one in my car, runs great, but I just ordered a 6010 mainly because of the rev limiter. Also, the timing curves on those pills all have 35 or 36 degrees of timing which makes me a little nervous because my motor is 10.5:1. Gonna dyno it as soon as I get the new box in, and I want to ba able to put less timing in if we determine that it's detonating.
tommy396 is offline   Reply With Quote
Old 04-02-2012, 05:55 AM   #6
GNCLONE's Avatar
Yeah, it works great for me too, just seems like the pills are all very mild/conservative.
Old 04-02-2012, 07:07 AM   #7
In-Zane Moderator
ZONES89RS's Avatar
When I went from the #6 pill to my own custom tune, it was a whole different car.
ZONES89RS is offline   Reply With Quote
Old 04-02-2012, 07:10 AM   #8
richard david's Avatar
I ran one on mine for a year and thought it worked good untilled I got the 6010 and was able to set my on timing curve. My best time with eld. box was 11.22 at 121 with the 6010 box it went 10.95 at 124
richard david is offline   Reply With Quote
Old 04-02-2012, 08:32 AM   #9
Hey Richard, I'm curious what your timing curve looks like? My car seems great on pill #6, but hily crap you picked up alot of time doing your own curve. Also GNClone, I thought 36 degrees was kind of aggressive? What does your curve look like? & are you running 93 octane?My car is mainly a street car, hasn't seen the track yet.
Old 04-02-2012, 04:04 PM   #10
GNCLONE's Avatar
Quote:
Originally Posted by tommy396 View Post
... Also GNClone, I thought 36 degrees was kind of aggressive? What does your curve look like? & are you running 93 octane?My car is mainly a street car, hasn't seen the track yet.
conservative in the choices I should say
No clue what my curve looks like, but yes, I run 91 or 93 whatever I can get
Old 04-02-2012, 04:21 PM   #11
In-Zane Moderator
ZONES89RS's Avatar
Gaining 3 mph sounds like it would be right, actually a custom timing setup that the car wants.
I run 35 total, I can run 87 just fine but it diesels when I shut it off, so I run 89. On nitrous of course I ran 93 and sprayed aviation fuel in with the nitrous.
Old 04-02-2012, 06:23 PM   #12
3pedals's Avatar
I tried all kinds of different curves, but in the end my car liked an almost flat timing curve. With the 9.6:1 setup it liked about 15startup, 38* from 800rpm up to 3500, then tapering down to 35-36 throught top rpm
On the engine dyno with my new 11.0:1 setup , it likes 15* startup, then 32* idle to finish rpm
3pedals is offline   Reply With Quote
Old 04-02-2012, 09:27 PM   #13
I have mine set at 37from 1200 to 4600 then drops to 32 the rest of the way shifting at 7000
Old 04-02-2012, 10:11 PM   #14
Why do you guys drop it down through the torque curve? Does it detonate if you don't? Just wondering, I wanna have a clue what I'm doing when I get to the dyno.
Old 04-02-2012, 10:16 PM   #15
3pedals's Avatar
mine ran the same mph through the lights with anywhere from 32* to 37* from 5000rpm up, and I decided to run 35* in the end,
BUT, it REALLY LOVED the added timing(38) at low rpm, - specifically below the rpm where the cam was "happy" - idle to 3500. This made the driveability improve dramatically.
Barrett
Old 04-09-2012, 11:36 AM   #16
I have been running one on my boat for years. I started with the dual plane, then got a Vic jr. Lost alot of torque!! I am running the ASA cam and it reacts to the different pills. I think I'm on #4 or #5. One thing I can't figure out is a consistant pop/back fire over the whole rpm range? Maybe a coil?Besides that it's a pretty good plug & play setup.
Moneyshott is offline   Reply With Quote
Old 04-09-2012, 03:51 PM   #17
GNCLONE's Avatar
I am using the number 1 pill, seems like a lot of people use/used the #6
Related Topics
Thread Thread Starter Forum Replies Last Post
LS1 Victor jr intake and MSD 6010 graderbird2004 Parts Classifieds 1 08-31-2014 06:18 AM
Auto Meter Shift Light Pill 6800 RPM speedtigger Parts Wanted 0 01-11-2014 12:33 PM
LQ4 Pinging 69importkilla Conversions & Hybrids 10 10-16-2013 12:49 PM
shifter pill? 95badboy Manual Transmission 2 03-24-2013 07:12 AM
Quit smoking pill ealucero1 Racer's Lounge 12 09-09-2008 10:48 AM
Tags
6, 7118, application, backfire, box, curve, edelbrock, edlbrock, ls1, module, msd, nos, pill, pills, pull, timing, will, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
