Go Back   LS1TECH > LS1-LS2-LS3-LS6-LS7 PERFORMANCE > Carbureted LSX forum
Sign in using an external account
Register Forgot Password?
Register iTraderTimeslips Photos Members Search Today's Posts Mark Forums Read Vendors
Search
Carbureted LSX forum Carburetors, carbed intakes, tuning tips for LSX enthusiasts
Welcome to LS1Tech.com!
Welcome to LS1Tech.com.
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, join LS1Tech.com today!
Thread Tools Search this Thread
Old 04-14-2012, 09:48 PM   #21
Garage is empty, add now
Trader Rating: 1
The heads are untouched stock casting.
__________________
84 Oldsmobile Cutlass: cam only lq9. All motor 7.07/11.17, 6.58/10.37 on the spray.
b_evans06 is offline   Reply With Quote
Old 04-14-2012, 09:58 PM   #22
GC99TA's Avatar
Trader Rating: 24
Cool vids man...it sounds great. In the nitrous video, you can hear the tone of the motor change (when the spray hits) about 10ft before you reach the 60' cone. Definately drop that window switch down and I'll bet you'll see a nice gain in your 60' and in your 1/8th ET. Only problem is you'll likely run out of RPM even sooner with those gears in the 1/4.
__________________
73 Camaro RS - Carb'd LY6. 11.07@120.49 NA (-781ft DA) and 10.09@131 N2O (-344ft DA)....Build Thread Here
99 Trans Am - AFR 205 Heads, Comp 228/230, Ported FAST 92, D&D Viper Spec T56, Moser 12 Bolt W/4.11s
GC99TA is offline   Reply With Quote
Old 04-14-2012, 10:32 PM   #23
Trader Rating: 1
Yea you can also hear it hit the rev right at the 1000ft mark. The front end comes down when I let off and then I got back on it. I think a gear change will be coming in the future.
__________________
Old 04-14-2012, 11:46 PM   #24
Trader Rating: 2
nice times put different gear and see what it does then
arob987 is offline   Reply With Quote
Old 04-15-2012, 01:29 PM   #25
Prorac1's Avatar
Trader Rating: 3
Send a message via AIM to Prorac1
Id say a differant gear, spray earlier, and up the shot a little bit and you got solid 9s on your hands. Congrats. Eric L
__________________
1997 Camaro SS, Headers, Cat back, ASAM cai, T56, 3.42s. Runs 12s, breaks 10 bolts.
http://s602.photobucket.com/albums/t...20Camaro%20SS/
1963 Plymouth Valiant. Tube chassis, LY6 6.0, Rapid motorsports cam, prosystems 780 carb, th400, 4000 stall.
http://s602.photobucket.com/albums/t...uth%20Valiant/
Prorac1 is offline   Reply With Quote
Old 04-17-2012, 05:48 PM   #26
trav-tech's Avatar
Trader Rating: 1
i didnt read the whole thread but one thing i saw in both the videos that i would say to try not to do the 1st gear spin in the water before the burn out. it flings water up in the wheel wells and it drips back on to the tires while your staging. you motor is making enough power to pull the burn out with what ever water gets on the tires from just rolling thru the box. just my 2 cents. looks good tho.
trav-tech is offline   Reply With Quote
Old 04-17-2012, 07:12 PM   #27
Trader Rating: 1
Default timeslip
CONGRATS ON TIME thats pretty strong for a cam only 6.0
rail2k is online now   Reply With Quote
LS1Tech
Pontiac Firebird
Paid Advertisement
Tags
balloon, cam, camshaft, carbd, carbed, converter, dimensions, dyno, engine, lq9, motor, plates, plugs, ptc, stock, tsunami
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.5.2
Advertising - Terms of Service - Privacy Policy - JOBS
Emails & Contact Details
