Would t-rex cam work? - LS1TECH
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Thread Tools Search this Thread
Old 05-03-2012, 06:56 AM   #1
Default Would t-rex cam work?
Would a t-rex cam work with this combo?
370ci
wiseco 12cc domes. 12.5.1 comp.
Scat rods
stock crank
cnc ls3 heads
victor jr intake
holley 950
e85.
Th400/4500 stall
4.10 gears
would it be to big or to small? Drag racing only
NOVACRAZY2007 is offline   Reply With Quote
Old 05-03-2012, 08:36 AM   #2
In-Zane Moderator
ZONES89RS's Avatar
Will it work, yes, will it net the maximum power from the engine combination? No.
ZONES89RS is offline   Reply With Quote
Old 05-03-2012, 08:55 AM   #3
probably would have to get custom cam ground. is there any off the shelf cams that would wok?
Old 05-03-2012, 09:46 AM   #4
In-Zane Moderator
ZONES89RS's Avatar
Probably not with beig carbed and the compression/head combination, but the market is vast and I do not know what is readily available, so there is a possibility.
Tags
12, 12cc, cam, cams, camshaft, carburetored, combo, head, ls1, ls1tech, ls3, rex, tech, trex, wiseco
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
