Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
what stall to use?
Old 08-01-2012, 03:42 PM
79nova's Avatar
Default what stall to use?
i found a good 200r4 for a good deal. my car is 78 chevy nova, using 2005 5.3 stock with edelbrock performer rpm set up, carb will be a quick fuel slayer, gear will be 3.42 or 3.73 still in the air, that stall converter should i use, car is around 3500pds, thanks ron c
Old 08-02-2012, 08:03 AM
jaybuller's Avatar
You could use a stock convertor with a stock 5.3 if you wanted to. if your looking for a little more giddiup id use a 2500 or so.
Old 08-02-2012, 08:20 AM
toxic99's Avatar
Stock would be fine but if you want some punch, 3200 minimum.
Old 08-02-2012, 01:38 PM
In-Zane Moderator
ZONES89RS's Avatar
Exactly, if yu want it to roll out and get into that power band quick but cruise fine, ateast a 3000-3200.
Old 08-02-2012, 02:48 PM
hifi875's Avatar
ive got a 5.3/2004r w 3.42 gears and 2400 stall. need more!! i might only run the once or twice a year so its not that big of a deal. I'd want a tight 3200 converter. my car ran a 13.2 @109 with a 2.0 60ft, so a converter would definitely help me out alot. i am going t56 though and atleast 3.73 gears. 3.42 isn't enough.
Old 08-02-2012, 10:57 PM
In-Zane Moderator
ZONES89RS's Avatar
I have 4.30 with the 6.0, works perfect, 2000 rpm was 76 mph, was a blast onthe street. May do it again, but the rear is going in the TA. The 91 that is gettin the t56 has 3.42.
