5.3 cam choices - LS1TECH
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
5.3 cam choices
Thread Tools Search this Thread
Old 08-08-2012, 08:34 AM   #1
Default 5.3 cam choices
Im putting together a 5.3 carb set up for my truck,3.73 rear.th350 for now (5 speed later) 3800 stall tci 242200.706 heads mild port work,stock bottom end.truck weighs around 3400 lbs.single plane intake.1 7/8 long tubes.want a cam with a tight c/l ,most are around 114.really like to be around 110 or less ,with about 228-235 @50 duration,and between 570 and 590 lift.any ideas?i think ill have to go custom because everything seems to be for fi setups,i really want a cam thats engineered for a carb set up.
slinginrods is offline   Reply With Quote
Old 08-08-2012, 09:08 AM   #2
check out speed inc tu2 cam 114 lobe,.581 lift for turbo app but looks great for carbed setup,its the one i went with,within weeks of starting the engine so no power numbers yet,just 2 cents
2lucke4u is offline   Reply With Quote
Old 08-08-2012, 03:04 PM   #3
In-Zane Moderator
ZONES89RS's Avatar
Anything in the low 230s with 110 and near .600 lift, I will see what I can dig up when I get home.
ZONES89RS is offline   Reply With Quote
Old 08-09-2012, 10:03 AM   #4
thanks
Old 08-09-2012, 08:19 PM   #5
Still lookin any ideas?
Old 08-09-2012, 10:21 PM   #6
In-Zane Moderator
ZONES89RS's Avatar
Saw a grind earlier, but i cannot remember, i need to see if i can look it up, i was trying to find the LSA on it, everything else looked right.
Old 08-10-2012, 09:42 PM   #7
Found this what do you guys think? http://www.dougherbert.com/gm-ls1-ls...ter-33966.html
Old 08-11-2012, 03:11 AM   #8
In-Zane Moderator
ZONES89RS's Avatar
Alright, I think the edelbrock large carb cam is calling you, 230/237 550 lift on a 110 lsa.
Part number 2216
Old 08-11-2012, 05:53 AM   #9
In-Zane Moderator
ZONES89RS's Avatar
.540 lift actually.
Old 08-11-2012, 04:19 PM   #10
topbrent's Avatar
Here is another choice to consider.
2002on22s:posted his cam choice in his carbed 5.3 truck.
This would be a strong runner on those EPS lobes.
Quote:
2002on22s:
I'm running a very similar ground EPS cam in my 5.3, 226/234 - .598" / .601" with 108 LSA & 105 ICL
It's nasty dude, you'll love it
He also sent me an PM that was a bit more detailed in the characteristics of the cam as installed in his 5.3.
Quote:
2002on22s:
"I did run it w/stock everything other than pushrods & I can tell you it sounded mean as hell & pulled like a mother past 2500 & that was with Holley 770 & the Victor intake tall boy, not the dual plane.
Anything below 2200 I really couldn’t tell a whole lot of difference, well I could, but the point I was trying to make is I sure didn’t lose anything down low & that was important to me. That was all ran off the MSD box."
topbrent is offline   Reply With Quote
Old 08-11-2012, 04:31 PM   #11
In-Zane Moderator
ZONES89RS's Avatar
If he had a smaller converter I would agree, but a 3800 will put that eddy cam in the kill zone.
Old 08-11-2012, 05:40 PM   #12
topbrent's Avatar
That Edelbrock 2216 cam sure is ground on some slow lobes. Would be likely be easy on parts, but a custom cam on faster lobes would/could/should definitely work better at all points.
Less seat timing, more torque, more power, better manners, easier to tune, idle, ect.
In the hypothetical example below, the EPS lobed cam would have 35° less overlap @.006 for the exact same events at .050!
An equivalent cam ground on the fast but stable EPS lobes would look like:
EPS .600/.603, 230/238 @.050, 279/287@.006 (adv) 110LSA/106ICL
Timing @.006"
Intake: 33.5°, 65.5°
Exhaust: 77.5°, 29.5°
Overlap: 63°
Timing at 0.050" Lift:
Intake: , 41°
Exhaust: 53° ,
Overlap: 14°
Edelbrock #2216 cam:
.540/.540, 230/237 @.050, 314/322 @.006, 110°LSA/106°ICL
Timing at 0.006" Lift:
Intake: 51°, 83°
Exhaust: 95°, 47°
Overlap: 98 °
Intake: , 41°
Exhaust: 52.5°, 4.5°
Overlap: 13.5°
Old 08-11-2012, 07:20 PM   #13
Is he sayin he had success running that cam on eps lobes with stock springs and retainers? I thought they were hard on valve train parts.with the 3.73 and the loose converter on 28 inch tires it'll come in fast.you think I'd be better with 4.11s? Damn this truck was supposed to be a dd if I wanted but I can't help but try to make it as quick as I can.might have to put a quick change rear in it lol.
Old 08-11-2012, 07:43 PM   #14
In-Zane Moderator
ZONES89RS's Avatar
That Edelbrock 2216 cam sure is some ground on some slow lobes. Would be likely be easy on parts, but a custom cam on faster lobes would/could/should definitely work better at all points.
yes, a eps grind like that would be great. I found what was cheapest and could use the cheapest valve train upgrades.
Old 08-14-2012, 11:32 AM   #15
called herbert cams today....guy said he didnt know anything about ls engines,tried to get him to send me a cam card on the cam i was interested in,"we dont have any,we get those made somewhere in california".sux because ive used there solid rollers in some of my bbc and sbc drag motors and they worked great.
Old 08-14-2012, 03:01 PM   #16
With that converter and rear years you shouldn't have a problem with any cam with a 3000+ operating range...def stick with a low lsa...Edelbrock looks like a great choice based on the fact it was engineered along with the intake and similar msd controller...when I get a cam fOr my carbed 5.3 I'm going eddy even though I usually don't buy their products
wildcamaro is offline   Reply With Quote
Old 08-14-2012, 03:18 PM   #17
thanks for the input,im leaning towards the eddy due to the low cost of valvetrain parts.
Old 08-14-2012, 10:40 PM   #18
The stunningman's Avatar
I put a TR224 cam in a carbed 5.3 S10 with a 5 speed, IMO it ran great, had over 400hp flywheel easy and great on gas too. I believe it was on a 110-112 max LSA. When you go 5 speed IMO your whole cam recommendation wil change. Your timing curve needs will. It pulled hard all the way through the powerband to 6500. The Thunder cam, Comp cam 918's and 7.4 pushrods were all bought here in the LS1 classifieds.
The stunningman is offline   Reply With Quote
Related Topics
Thread Thread Starter Forum Replies Last Post
Carb'd Cammed 5.3 Intake/Carb questions Wisco S10 Carbureted LSX Forum 2 08-24-2016 09:04 AM
Heavy Car cam selection - 5.3 + Carb + TH400 + 650CFM ? APillow Carbureted LSX Forum 4 04-24-2015 01:08 PM
Cam question for 5.3 Mxracer394 Carbureted LSX Forum 8 08-21-2014 11:56 PM
5.3 with torquer v2 cam.... Dart 225cc heads too much?? Nohatch Carbureted LSX Forum 5 12-30-2012 06:05 PM
Looking for opinions of carbed 5.3 s10 build 95FbFormula Carbureted LSX Forum 12 12-12-2012 05:11 PM
Tags
230, 237, 53, 540, 63, cam, carb, choice, ls1, nova, set, tech, tu2, turbo, ups
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
