99 carb'd camaro
this is the pump that i ran with my factory fbody tank and an in-tank walbro setup w/ my quick fuel carb.
http://www.jegs.com/p/Aeromotive/Aer...50089/10002/-1
You just have to make sure your return line is big enough. I had problems regulating down my pressure because I used the 5/16 evap hard line as the return. It could flow enough volume to bring the pressures down to 6psi. I have an aftermarket intank pump that pushes a TON of fuel so that may have been some of the problem. Either way I had to run 1/2 inch hose all the way to the tank. Just throwing that out there.
