Help me figure out my C4 swap - LS1TECH
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Thread Tools Search this Thread
Old 08-21-2012, 06:36 PM   #1
Default Help me figure out my C4 swap
So recently I decided to put a carb on my 84 corvette and really like it, The stock longblock has 150k miles on it and too save you a long story iv been wanting too cheaply put a Ls based motor in the car, and I want too stick with the carb because I think it would be unique.
this is a cheap as I can do it type build, not because I am cheap but because I find it fun.
So for now 4.8/5.3.. long term goal is a aluminum block with a destroked crank such as LS1 block with 4.8 crank.
I want to keep my stock hood, is the LS1 setup going too be taller then a SBC? the carb setup on there now is a tight fit already.
I have a dana 36 rear end with 3.07 gears, for that reason I would really like too swap a superT10 into the car and eliminate the 4+3, the overdrive unit is weak and will probably not last with my goals, I know its possible too mount a T10 too a ls1 but can I make it strong enough for a 500hp motor thats not super torquey?
jay7199 is offline   Reply With Quote
Old 08-21-2012, 06:55 PM   #2
$750 L98's Avatar
4.8! You can always build it later as well, it will still be lighter than the dressed motor in it now....and if you are wanting to do boost, the 4.8 seems to like it.
I have only seen a couple carbed LS C4, but it looks like clearing the stock hood will be totally dependent on how wild of an intake you buy, they don't LOOK any taller than a standard 350 when mounted.
I looked into the T10 as well but consensus seemed to be that it won't hold big power. Torque ratings for it are around 300ft/lb.
$750 L98 is offline   Reply With Quote
Old 08-21-2012, 07:21 PM   #3
In-Zane Moderator
ZONES89RS's Avatar
Clear the stock hood with carb and LS? Not likely, but there are possibly intakes out there I have not used that may be low enough. A cowl would be sweet anyway. I would swap to a T56 6 speed but that is against your budget it would seem yet the adapting components to make what you have work? Might be pricey as well. Corvette and budget in the same sentence are rare.
ZONES89RS is offline   Reply With Quote
Old 08-22-2012, 02:42 PM   #4
the T56 wouldn't work well with a 3.07 rear end would it?
If i have too ditch the manual I might consider it just too get the swap done.
Is there a low profile single plane ls intake out there?
Old 08-22-2012, 04:36 PM   #5
In-Zane Moderator
ZONES89RS's Avatar
That is the one thing about carbed LS, the intakes are aggressive. The t56 came with 3.23 in many cars, you don't have to use 6th and they are rated at 450 foot pounds. I beat mine like a stepchild. There may be a lower intake like a dual quad, it looks lower but I cannot lie to you. It is making a air cleaner work that is the issue.
Related Topics
Thread Thread Starter Forum Replies Last Post
Low Compression + Pump Gas... How Much Boost? Slow94Formula Forced Induction 40 03-07-2013 10:48 AM
lsx destroked stroker combo? mustang_1noskid General LSX Automobile Discussion 9 09-16-2012 03:47 AM
7500rpm Stable Cathedral Head Valvetrain sydneyACE Generation IV Internal Engine 25 01-14-2012 11:17 PM
Budget Carbed LS swap info ZONES89RS Carbureted LSX Forum 0 01-12-2011 08:55 PM
Help deciding between lm7/lq4 for 240sx jmsklmn Generation III Internal Engine 12 03-02-2010 07:46 AM
Tags
36, 84, build, c4, carabator, carb, carburator, carburetor, corvette, dana, engine, gear, ls, put, swap
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
