Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
What fuel pump are you using?
Old 06-12-2013, 02:26 PM
streetknight2's Avatar
Default What fuel pump are you using?
And what do you use your car for?
I'm currently running a Holley Blue pump on the Mustang which works great, just loud, but it's a track only car so I don't care.
BUT, the Fairmont build will be a driver and I'm looking for something quieter.
The Holley HP series looks like it may work, what do you use?
http://www.summitracing.com/parts/hly-12-150
Old 06-12-2013, 02:59 PM
newschool72's Avatar
Aeromotive HP700 with a custom in-tank install done by yours truly. It is quiet above 1/2 tank, then the pump starts getting uncovered and you can hear a light hum . It is good to something like 900 hp in a NA low pressure app. I run mine at 43 psi because of the FAST EZ, but I chose it because if ,down the road, I want to exceed the 650hp the FAST will handle I can throw a big carb on and shoot for the moon. It will work in both carb and fuel injected setups.
Old 06-12-2013, 03:15 PM
In-Zane Moderator
ZONES89RS's Avatar
Aeromotive street and strip. Good to 750 hp. Way quieter than my holley blue.
Old 06-12-2013, 03:50 PM
Thanks, I'll look into them.
Zones, what regulator you using?
Old 06-12-2013, 04:04 PM
lsxnotch's Avatar
Glad to hear the holley blue will work....i got one laying around.....did you also use the regulator or did you go with a different one...
Old 06-12-2013, 04:52 PM
In-Zane Moderator
ZONES89RS's Avatar
A cheap bypass from quick fuel. Works great.
Old 06-12-2013, 05:04 PM
Doug G's Avatar
Aeromotive SS pump off a buddies 9.20 car. He upgraded and I got it cheap. (also using a -8 line)
Street/Strip use
Old 06-12-2013, 05:11 PM
Street/Strip use
I think 8an is the right size for a 500-700hp LS. That is the only thing I will have to change out later on mine if I go big in the future. The line set-up on mine is 6an for the fuel injection. Sorry about the slight jack, but thought it might be relevant .
Old 06-12-2013, 05:57 PM
89gmcs15's Avatar
I've got a edelbrock quiet flow, the big one. All 8an from tank to carb bowls. I've got a deadhead quickfuel regulator and I made 400 whp on low 29* timing thru a 3400 stall th400 on a dyno dynamics (450+ dynojet numbers) the fuel pressure never flinched set at 7 psi.
I normally idle around our small town and smoke the tires in the country but I want to hit the 1/8th and shoot for 6's. it's really not all that quiet but it flows good for the carb.
Ps. Newschool, I'd still take that fast ezefi off your hands, i still have that big carb your lookin for
Old 06-13-2013, 05:24 AM
Pop N Wood's Avatar
People say the Carter pumps are more quiet than the Holleys. If you really want quiet then look for an in tank set up. EFI pumps work fine for carbs when used with the right regulator.
Whatever you do don't go too big on the pump. After a certain point it just adds noise.
Old 06-13-2013, 07:06 AM
The stunningman's Avatar
I am running the aeromotive street strip pump on Freddie it is nowhere near as loud as the blue pump (it replaced) but does make a pronounced hum. The Carter is a rotary design and won't be pronounced. Here's the one I am going to run on my Box top pure street project. I am going to run 1/2" line from the tank to the regulator splitting up 3/8" from there.
It is 3/8 NPT most other carter pumps are not.
http://www.summitracing.com/parts/crt-p4600hp/overview/
Old 06-13-2013, 07:18 AM
snook's Avatar
Have heard these are quiet
http://www.jegs.com/i/Carter/180/P4601HP/10002/-1
Old 06-13-2013, 09:02 AM
cruisin'73's Avatar
Default Carter=LOUD
I would have to disagree on the Carter being a quiet pump, at least my application! I can hear that little f*cker all the time. It is ruining the otherwise lovely rumble of my exhaust and driving me crazy! I did use the 3 rubber isolators that come with the pump. But I think I am going to have to rubber mount my entire pump and filter assembly and maybe even make a bottom cover. I also think mounting in front of the fuel tank turns the trunk into a reverberation chamber! Here is a pic of the install and the youtube vids on my first start ups a few weeks ago. You can hear that damn thing churning away even with the engine running. Though I do have 500miles on the car now and I think it has started to revhone itself a little quieter. That or I am going deaf to that frequency from listening to it!
With the full exhaust system on
Old 06-13-2013, 09:08 AM
LOL! yea ,Im a fan of "in the tank" pumps. I had my pump on the frame rail before I went "in tank", and It would drive me crazy. Not bad at all now.
Old 06-13-2013, 11:55 AM
Pop N Wood's Avatar
I'll bet if you get that carter lower it will be less noisy. My Mallory pump quieted down a good bit when I switched to a lower pressure drop prefilter.
Old 06-13-2013, 12:16 PM
cruisin'73's Avatar
I think you may be right about getting it lower. The more fuel I have in the tank the quieter it is. To bad I have a tire rub issue so I am not fulling past 1/2 tank right now! The Russel pre-filter is a 100Micron screen I do not think it is causing to much restriction.
Besides the noise the performance has been perfect. Moves a TON of fuel, though it is suppose to maintain 5PSI, I often see the gauge bouncing above that.
Old 06-13-2013, 03:41 PM
Your bracket looks like a diving board with the pump mounted at the end of it. And as Pop n wood said it mounted to high. You'd burn it to the ground if you had a blue pump mounted on that. Mount the pump lower and on the factory bracket mounted solid to the frame.
Old 06-13-2013, 03:51 PM
onefast84's Avatar
two Holley blues here, one for the ls, and one for the nos! Thinking about going to the Holley dominator twin pump. Its a street/strip car.
Old 06-14-2013, 05:46 AM
tommy396's Avatar
I run a Jegs pump (95913) mounted to my frame rail, been running it for 3 years, but I have wide open zoomies that drown out the noise. It's definitely noisy but only 79 bucks.
Old 06-14-2013, 06:44 AM
BottleFedZ346's Avatar
I run the A1000, -10 feed/-8 return.....
Quick Reply: What fuel pump are you using?
