1988 Camaro IROC-Z 5.3/4l60e swap
Yeaaaaa im not sure about a speedo just yet. My car had a mechanical speedo from the factory so im not sure just yet on how im going to hook an electrical one up. The 4l60e has a vss that the tcu plugs in and the speed is displayed on the handheld, so i can look on there for speed. I also downloaded a speedo app that is pretty accurate.
Small updates, I've been doing a lot of rust removal and painting.
Before.
After.
Got the old electric TBI fuel pump out as well.
Cleaned a lot of rust off of the drive shaft and painted it.
Painted these crappy s10 wheels I got for free, they look ok. Don't worry the car doesn't sit that high, it's on a lift haha.
Got the fuel pressure regulator mounted and the line ran too it. I need a new guage though, this one is all flimsy and cheap.
Before.
After.
Well people, I have some bad news. I was inspecting inside the spark plug holes just to "see" if it had flat top pistons (4.8) or dished pistons (5.3). And the first hole I looked in cylinder number 4, I rotated the motor with my big ratchet and noticed I could only rotate it about 3/4 a full turn. It would come to a dead stop, while I was scratching my head I meered into the cylinder hole, and looky there I saw 3 large chunks of metal and the piston had a nice big hole in it.
No telling what all happened in there, I can't believe I got jipped on a "good working engine". It really sucks because I was planning on getting this running in about 45 days.
#34
I'm doing a 5.3L swap on a 1984 Trans Am, and I just bought some long tube headers. Are you going to use an x pipe behind the trans? Also, will you be able to get the manifold and carb to fit under the stock hood? I haven't found an example of that yet.
#37
Well I guess I will update this build somewhat. It's going slow because of school, but I will graduate with an associates degree on May13th! So after that this thing can really get rolling. I've got the ls1 oil pan and pickup tube. All I need to stab it in the car is a nice converter. I'm thinking an FTI 3200 will suffice. I may need to purchase a new carburetor as well.
