Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
edelbrock pills
Old 07-18-2013, 09:44 AM
billymgb1000's Avatar
Default edelbrock pills
can someone please explain just how the pills work that come with the edelbrock ignition mod I can not find just how they work thanks in advance
Old 07-18-2013, 10:50 AM
LS1MCSS's Avatar
Were there no instructions with the box? If so, they tell you what the pills are best used for.
Old 07-18-2013, 11:36 AM
niscur29's Avatar
They are pre programmed "TUNES" from MSD that plug into the side of the box. I believe each number in pill you go up the more agressive the tune. I think two pills are setup for the 2215/2216 cams and number 3 is preloaded onto the box. You dont need to use the pills if you want to customize your own tune.
But the manual goes into more detail. Google it if you are missing it and read it.
Old 07-18-2013, 04:19 PM
wildcamaro's Avatar
If its the edelbrock box you can't custom tune the pills are your only option
Quick Reply: edelbrock pills
