Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
How did you mount and route your msd harness
Old 02-04-2013, 07:20 PM
Houston_t's Avatar
Default How did you mount and route your msd harness
got mines mounted to the intake and cant find a good way to route it only tried for a few but shouldnt be this hard, crank sensor wire is kinda tight.
Old 02-04-2013, 07:36 PM
Doug G's Avatar
Mounted mine where the battery used to be.(pass. side front at the core support)
Old 02-04-2013, 10:15 PM
FakeSnake's Avatar
i deloomed mine and redid a few things because i didnt like the way msd did it... might be able to make it fit better like mine.... more pics in my build thread
Old 02-05-2013, 01:59 AM
In-Zane Moderator
ZONES89RS's Avatar
Have put mine behind the engine on the fire wall, passenger side behind the strut tower, intake, always ran the wires as well as I could. I'm not super picky.
Old 02-05-2013, 05:46 AM
Houston_t's Avatar
Would I need the extension harness if I want to move it from the intake ? Gonna try and play with it some more today after work
Old 02-05-2013, 08:41 AM
Prorac1's Avatar
No need for the extension harness. I have mine mounted in the glove box with the standard harness. Eric L
Old 02-05-2013, 09:13 AM
TXsilverado's Avatar
damn. my harness is nowhere near that longmine is just hanging loose right now. havent decided where i want to mount it yet.
Old 02-05-2013, 09:19 AM
Prorac1's Avatar
Mine is just an MSD 6012 with the standard harness. Had plenty of length. But im not working with a truck either, lol. Eric L
Old 02-05-2013, 09:21 AM
the truck in my sig is long gone. sold it and someone stole it from the new owner and stripped it down. new project is a s10.
Old 02-05-2013, 10:02 AM
89gmcs15's Avatar
My 89 gmc s15 with a 6010 has enough wire to reach from the engine all the way to the seat. I mounted it on the firewall inside by the passenger. I routed the wire thru the heater box hole since my heater is removed. I'm working still on filling all the holes on the firewall now. But the poor girl is buried in a snow bank
Old 02-05-2013, 10:33 AM
Prorac1's Avatar
My wiring harness passes through the firewall directlly behind the intake, dead center, makes a turn and runs to the glove box. As stated above, I have had mine sitting on my lap before. There is quite a bit of harness if you route it correctlly. Just make sure you make the tuning port acessable where ever you mount it. That plug is pretty big. Eric L
Old 02-12-2013, 10:08 PM
68fleetside's Avatar
So Msd 6010 comes with longer wire then what it shows in pic??
Old 02-14-2013, 11:26 AM
Prorac1's Avatar
I dont know the exact measurement, but its pretty darn long. From memory, if I had to guess, id say almost 4 or 5 feet. Eric L
Old 02-18-2013, 08:15 PM
Blue Knight's Avatar
I mounted mine in the passenger side kick panel.
Old 04-11-2013, 09:53 AM
there must be a short and long harness. mine is nowhere near 5' long.
Old 04-11-2013, 11:17 PM
Prorac1's Avatar
Is it a 6012? Maybe the 10 and 12 are different?
Old 04-12-2013, 05:53 AM
darren roar's Avatar
My C10 i mounted it in the glovebox and snaked the harness thru an existing hole in the firewall. My caprice i made a aluminum plate and put it on the passenger's side inner fender and wrapped the harness behind the motor.
[IMG][/IMG]
[IMG][/IMG]
Old 04-12-2013, 07:00 AM
Pop N Wood's Avatar
The "extension harness" is actually a shorter version of the standard harness designed to mount the box on the intake. It might come with the Edlebrock kit that packages the intake and box.
I just mounted mine on the passenger side fender in front of the motor. I might someday move it under the dash, but if I do that I will add a bulkhead connector make it easy to work on.
Old 04-12-2013, 09:19 AM
if anyone wants to trade their 5' harness for the shorter version let me know. i'd like to mount it on my passenger fender but It looks like the fire wall is my only option.
Old 04-12-2013, 06:58 PM
In-Zane Moderator
ZONES89RS's Avatar
Of all of the 6010 and 6012 o have got, they all seemed the same. The 6012 just had a extra long cam sensor wire set for the front mount sensor on the timing cover.
Quick Reply: How did you mount and route your msd harness
