90 rs to ls carb ?'s
I will be doing ls1 carb setup on my brothers 90 rs car,the 350 tbi it had let go.Just had a couple of questions mostly clarifications.I've done the reading just need some final input.Will be using the 700r4 I know....for now.
What throttle bracket do you have?I have some in mind.Will be using a 650 dp
What tv bracket did you use part#?Edelbrock#350-8029?
Hughes #HP3795 flex plate adapter is the one to use with the 700r4?Using the 01 ls dished flywheel.
Old School Heavy
http://www.ebay.com/itm/New-OEM-Flywheel-Flexplate-Flex-Plate-w-Spacer-GM-12621399-12563532-4-8L-6-0L-/400644954082?pt=Motors_Car_Truck_Parts_Accessories&hash=item5d484cd7e2&vxp=mtr
Bowtie Overdrives TV cable kit (TV Made EZ)
http://www.tvmadeez.com/4100_cam/
Thanks Ive seen that gm flexplate didn't know my friend had one,but still bought the other type of trans adapter just in case something comes up.Bought a couple more things will see how it goes.
