ready for upgrades....I think.
Talk me into it guys. Ran a best of 6.34 last season. Carb close but still a little left. The plan was to install race seats and remove stickers, a savings of 68 lbs, pull heads and mill.,010 more off, do some mild hand porting on int and exhaust mostly exhaust side. More of a good clean up, like blend guides and such. Then I have installed a 4.30 gear for this year. I feel like the gear and weight loss should put it at about 6.25. Would you mess with pulling heads for mill and minor port work and port match? Heads are milled. 020 now. Comp is at about 10.5-10.7-1 now. I know it's last minute. But I need motivation. Thanks in advance.
I think bumping compression on your engine (LY6 stock bottom end I think?) would definitely be a good thing.
Just looking at some numbers with the comp calculator, even with the piston .005" out of the hole and heads running approximately 65cc chambers, still be looking at just under 10:1 static comp, and with your cam dynamic around 7.6:1 that being with a guesstimate of 283* adv. duration on the intake lobe, going by the comp QXI lobe which is 231@.050/.622" lift, pretty sure same specs I read on your cam.
