Zones or any other 3rd gen guys.
I am looking into putting my 01 ls1 into my. 89 Iroc . Carbing it because basically the local tuners decided they aren't taking in new customers. Will be easier to wire too .
What I want to know is it possible to get this thing in the low 7s high 6s in the 1/8? What cam and what stall for a th350 would you suggest? I may do a trans brake .
I will be shelling out money for the hawks headers . I wish the one company would come out with bigger primaries on theirs. I have a s60 with 3:73s . Full suspension, gutted car. . No air . I am planning on running a manual steering box.
The motor helped my 4th gen do 7.95 in the 1/8 . This is bone stock long block. No headers. Just a 3600 fti stall, 3:73s, lid and off road y pipe. Thanks in advance.
In-Zane Moderator
My 6 liter with a carb and trex went 7.1 all day on motor at 3150 lbs. so yes, your goal is not a problem. Custom cam and some ported heads will make damn sure. I would like to see a deeper gear in the rear, a 3.73 is not that great, but with the right converter and some 26x10.5 slicks, it will still do the deed. Especially with a brake.
Thanks for the reply.
I was thinking of contacting Brian Tooley to set me up with a cam package. I may have the 3:73s replaced with 4:10s. I am still hoping to make the 15 mile trip to the track and cruise around town in it.
I have access to a trailer but my 95 silverado needs some *****. So I would have to borrow a truck until I put a better motor in mine.
Agreed with Zones go with the 80e and TCI full manual valve body it's just like having a th400 but with an overdrive and a lockup so you still get great gas mileage. It's a bit pricey but well worth it.
No progress on this. I decided to leave the 01 z28 alone. I bought a 05 6.0 long block. Has bad cam bearings. My brother has a th350 long tail I plan to use. Saves me money one cause I already have a 4l60 length strange driveshaft to go with my s60. Car won't be driven a whole lot. I am hoping to bracket race it in the 7.50 class at local track.
Didn't recognize you till just now Matt. I'll have to hit you up for advice on the mullet board when I get into this project. I'd be more than happy if my car ran close to your times.
