750 holley dp mach. seconds? - LS1TECH
Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Thread Tools Search this Thread
Old 05-28-2014, 05:58 PM   #1
Default 750 holley dp mach. seconds?
I'm building a l99 with ls3 conversion. Just ordered a 229/236 cam package from tsp. I could be off on the cam numbers as I don't have them in front of me. I plan on doing trunnion upgrade with comp cam kit. Does the 750 holley carb seem to be the correct one for the job. This is my first v8 and carb build. This is totally new territory for me. I plan on running a super t10 behind it. Any other ideas or advice would be greatly appreciated. Like I said I'm a newb. I'm going to be installing this in my 240sx drift car.
thursdaymike is offline   Reply With Quote
Old 05-28-2014, 06:51 PM   #2
750 should work fine. Having said that the cam and intake have an impact on the carb size, also gearing, intended use, RPM range and vehicle weight.
The best thing you can do is contact a reliable carb builder with all the info to recommend a carb.
Good luck.
ss performance is online now   Reply With Quote
Old 05-28-2014, 07:19 PM   #3
Thanks ss
Old 05-28-2014, 10:00 PM   #4
more info?? but should be around that size.
dogsballs is offline   Reply With Quote
Old 06-23-2014, 09:53 PM   #5
What's your max RPM?
Midsouthperformance is offline   Reply With Quote
Old 06-24-2014, 05:18 AM   #6
Pop N Wood's Avatar
750 will work great. Probably 90% of the guys on here run one. You are probably moving enough air to use an 850, but the 750 should be easier to set up and tune for a newby.
Pop N Wood is offline   Reply With Quote
Old 06-24-2014, 02:09 PM   #7
In-Zane Moderator
ZONES89RS's Avatar
I think that the pro form me and some others use as well as quick fuel 750s might flow more than a stock 750. Could be wrong.
ZONES89RS is offline   Reply With Quote
Old 06-24-2014, 10:56 PM   #8
The new Holley 750 HP has an idle by pass to help with bigger cams.
Old 06-25-2014, 05:23 AM   #9
Doug G's Avatar
A DP carb with a manual box will be fine. That cam isn't huge, but not knowing the LSA and intended use doesn't help.
A little more info will help a lot
Doug G is offline   Reply With Quote
Old 02-02-2017, 02:13 PM   #10
So I've found these 2 part numbers: 12625033 and 12499224. From what I've looked up they have the same specs. Both GM performance blue springs....so which ones do i get?
JPCTS-V04 is offline   Reply With Quote
Old 02-03-2017, 04:20 PM   #11
Quote:
sorry fellas, wrong thread...
Old 02-03-2017, 04:26 PM   #12
Old School Heavy
speedtigger's Avatar
Quote:
A 750 CFM 4150 series Holley with mechanical secondaries will be a great choice. Just be ready to tune the accelerator pump discharge nozzles for throttle response and maybe adjust the main jets for optimal air fuel ratio.
speedtigger is offline   Reply With Quote
Old 02-03-2017, 05:51 PM   #13
Pop N Wood's Avatar
I hope he got his carb sorted out in the 2 1/2 years since he posted the thread
LOL
Related Topics
Thread Thread Starter Forum Replies Last Post
Dual dominators, tunnel ram 408 GarrettM Carbureted LSX Forum 26 06-04-2016 08:57 PM
Holley 750 blower carb from The Carb Shop--fresh oldskoolss Parts Classifieds 0 12-02-2015 09:11 PM
Will a stock LS1 cam pull too much vacuum at idle? Swap cam for carb application? Cobra4B Carbureted LSX Forum 5 07-02-2012 05:47 PM
Help me on a budget build my motor on what is the best top end setuo david068513 Small Block & Big Block Chevy Specific 22 06-30-2012 06:27 AM
WTB Holley 750 double pumper mech 2ndaries duff man Parts Wanted 6 02-17-2008 04:47 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
