Carbureted LSX Forum Carburetors | Carbed Intakes | Carb Tuning Tips for LSX Enthusiasts
Convertor the issue?
Old 06-22-2014, 07:15 PM
LowDime84's Avatar
Default Convertor the issue?
Looking for some insight as to the car leaves like a donkey 1.6 60's and most are pointing in the direction of my convertor being to tight...Havent sprayed it yet but seems others on the board are having better luck on the motor than I have been 6.90's on the motor 1/8 mile.. I know the car is built for the bottle but seems im on the slower side of the spectrum for the power made 510/426
Full weight 92 coupe
408 ls
950 carb
Vic jr
ported l92's
247/262 cam
4l80 trans
4k billet tripple disk stall built for 350 shot
4;10 geared
Here is a dyno graph to hopefully shed some light... what stall speed would you reccomend? thanks for any help [IMG][/IMG]
Old 06-22-2014, 07:23 PM
VLS1's Avatar
Most guys are running converter's suited to all motor, or a small shot. Of course your converter is going to be tight!
Old 06-22-2014, 11:54 PM
6D9
6D9's Avatar
See how it runs on spray first. If your happy and it 60's were you want it on bottle leave it alone. How much you plan to hit it out of the hole?
Old 06-23-2014, 12:03 PM
LowDime84's Avatar
Its a local shop and just took it there for dyno only made 3 pulls and drove it home....I noticed that it doesn't seem to read till upper rpms but what are you saying looks off? I may hit up another dyno....and to answer the other question the car will work its self to a 300 in the near future
Old 06-23-2014, 12:38 PM
WE TODD DID's Avatar
If the converter was built for that much nitrous, there's no wonder why it doesn't 60' on the motor. What were you expecting exactly? Can't have the best of both worlds.
Old 06-23-2014, 01:32 PM
LowDime84's Avatar
I understand that a nitrous convertor was going to hurt the motor passes but judging from a couple similar setups on here it seems to be off a lil bit....no big deal was just seeing if it looked to be in the ball park for my combo....as I didn't expect miracles on the motor in the first place
Old 06-23-2014, 02:03 PM
Old School Heavy
speedtigger's Avatar
Post a timeslip. How much spray are you planning on? What is the actual raceweight? What RPM did you shift?
Old 06-23-2014, 09:24 PM
dogsballs's Avatar
n/a 60ft with nitrous convertor will always be far from optimal. i'd say 1.6 aint bad considering, might even find you pick up more down the end of the track as its not slipping
graph looks fine to me
Old 06-24-2014, 04:28 PM
LowDime84's Avatar
[IMG][img=http://s30.postimg.org/5m11dfmst/CAM00565.jpg][/IMG] here's on of the slips
Old 06-24-2014, 05:56 PM
Old School Heavy
Now that we have the timeslip, we need to know the weight of this thing. That is really the other half of the equation.
I have to say though. With that much camshaft, I would think you would have a higher peak HP with those heads and intake. I would love to see the cam card for the full specs on that camshaft.
Old 06-24-2014, 06:01 PM
VLS1's Avatar
Is that supposed to be RWHP?? Assuming race weight of 3200LB and approximate 1/4 mile of 10.79 going by your half track (mph is pretty low) you are making 510 at the motor going by Pro Systems racing calculator - not at the tyres!
Old 06-24-2014, 06:12 PM
Old School Heavy
How can he trust what anyone says who spells tires with a "y"?
Old 06-24-2014, 06:21 PM
VLS1's Avatar
Old 06-24-2014, 07:45 PM
LowDime84's Avatar
I'll see what I can do....should have the card handy, once I get it I'll post it up...thanks for all advice....may throw it on another dyno to see if something is up with the one I went to
Old 06-25-2014, 12:35 PM
LowDime84's Avatar
[IMG][/IMG]
Quick Reply: Convertor the issue?
