It fits, 99 s10
Are those current performance mounts the same as Transdapt #4516 mounts? They look the same. Did you use the poly or standard rubber? How much clearance do you have between the engine and firewall?
Ill get a pic monday left the hood on and the front core support in had no accessories on the front and no crank pulley just went slow had to push the hood higher than the prop rod will go
